Htp er70s-6
发表于 2021-8-31 23:17:20 | 显示全部楼层 |阅读模式
Since my LWS no longer carries HB-28 wire (my favorite), I have been looking for a suitable replacement.  The spool of L-56 I got was not wound well and I had some wire feed issues.  After hearing some good things about HTP products, I ordered an 11lb spool of their ER70S-6.  I welded with it today and ended up using about half a spool.  I really like it.  It has good wet out and runs really smoothly.  I really like how it is wound on the spool, which makes it feed very well.  This was my first order with them, but so far, I'm impressed.
Reply:You think their wire is good, you ought to try their welder!  HTP Mig 2400 is an outstanding welder.  I like the wire too, and have never had problems.  I last bought a 30# spool, but am about of the opinion I like the 11# better.  They'll ship 2 11# spools for the price of 1, and the 11# spool spends less time in the machine.  Fresh, clean wire is good!  I'm a hobby guy and don't use wire fast enough on a 30# spool.  On the other hand, the 30# spool still feeds and welds like it did when I put it on...Tracker401
GMT+8, 2025-12-27 18:41 , Processed in 0.164562 second(s), 18 queries .
