Questions on rigs
发表于 2021-8-31 23:17:20 | 显示全部楼层 |阅读模式
Hey;I layed bead with my Weldanpower 225 and a Hobart stickmate, both at DC - and 130 using 6013. Seems that the stickmate buzz box lays rod better, what are your opinions on the rigs?Tanks
Reply:If you're comparing them both at 130A, that might be the problem. Different machines will run different at the same "indicated" setting. You need to not look at the dial, and adjust your amperage by results while welding. Once you get them set to their best performance, then compare the two."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
GMT+8, 2025-12-27 18:42 , Processed in 0.106129 second(s), 18 queries .
