Asme ix pqr
发表于 2021-8-31 23:17:17 | 显示全部楼层 |阅读模式
If I qualify an ASME IX PQR using GTAW root (3mm WT) / GMAW fill & cap (6mm WT). Can I use this PQR to support production welding using the GTAW process only. Do the impacts and other test results etc. still support? thanks.
Reply:Originally Posted by AdamTIf I qualify an ASME IX PQR using GTAW root (3mm WT) / GMAW fill & cap (6mm WT). Can I use this PQR to support production welding using the GTAW process only. Do the impacts and other test results etc. still support? thanks.
GMT+8, 2025-12-27 18:42 , Processed in 0.101657 second(s), 18 queries .
