3G root pass
发表于 2021-8-31 23:17:17 | 显示全部楼层 |阅读模式
Doing a3g vertical up open root mma with 6011 3.2mm rod for root pass using the keyhole technique. It's for a test which will be x-rayed. Anyone got any tips on rod angles and if restarts have to be grinded down too. Any tips would be appreciated
Reply:One thing I do for a restarts. When the rod is getting short, and I know I have to stop. I punch the rod right through the plate / pipe. This will leave a small hole. Then I feather this area down with a die grinder with a cut off wheel on it. Start my next rod 1/2 to 3/4-inch above this hole, drop back on top of the hole, fill the hole, and move on out.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
GMT+8, 2025-12-27 18:51 , Processed in 0.107081 second(s), 18 queries .
