90 Degree gas fitting
发表于 2021-8-31 23:17:16 | 显示全部楼层 |阅读模式
My welding cart is small and the gas fitting on the back of the welder is uncomfortably crammed against the tank.  Can I install a 90 degree fitting on the back of the welder to reroute the hose without messing up anything?
Reply:My Lincoln 175 was like that too, but it worked.  Yes, you can put a different fitting on there.  If there are pipe threads for the fitting, I suggest using some liquid teflon (PTFE).  A pic would help.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Thanks.  Yeah, there's just a female connection on the back.  I'm not sure of the thread size at the moment, but that easy enough to figure out.
Reply:Fitting may be a flare type fitting vs a NPT pipe thread. Should be easy to tell since you have the hose that attaches to it. Flare fittings though are a bit harder to locate though. You may find something at your welding supply. Hydraulics shops also have a selection of flare types and sizes..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Here's what the hose looks like.
Reply:Ah, no reason for sealant on that guy then.  You should be able to find something at your local hydraulics repair shop.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Wonder if Ace Hardware has anything.  Dacula doesn't have much for shops.
Reply:http://www.arc-zone.com/index.php?ma...oducts_id=2525
Reply:Perfection!  Thank you.  Is that what mine is...  this "B" size?
Reply:Originally Posted by BonemaroPerfection!  Thank you.  Is that what mine is...  this "B" size?
Reply:Found a guy selling these on Ebay for $1.99.
Reply:You got the link???I was looking for them too.~John
Reply:Yep.  Only 8 left.http://www.ebay.com/itm/Western-Ente...-/200625687509
Reply:Hey thanks a bunch.I just bought two.~John
Reply:I just changed my order to get two as well.
Reply:Screamin deal!!!Get them while you can!!!
Reply:My adapters came in today.  Perfect.
Reply:lovely,\mine come in tomorrow or the day after.~Johnpix soon too.
Reply:This is the Back of my Maxstar.Awesome!!!!!~John
Reply:here's the one on my HH 135.Perfect!!!~John
Reply:I bought one of these, but I think i'm going to convert my welders to all quick connect fittings for gas and torch connections.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by GambleI bought one of these, but I think i'm going to convert my welders to all quick connect fittings for gas and torch connections.
GMT+8, 2025-12-27 18:51 , Processed in 0.111075 second(s), 18 queries .
