Overhead aluminum tig?
发表于 2021-8-31 23:17:15 | 显示全部楼层 |阅读模式
Just got asked if this is possible. I replyed I'm sure it is, not sure I can pull it off!What do I need to know about this? Settings it's a snow mobile trailer guset under the deck, about 1/8" inside corner!I'll practice this on scrap first of course!Any advice and or tips would be appreciated!!! Thanks in advance!
Reply:Tig doesn't matter what position your in nothing special
Reply:I agree ^^^ tig is nice that way This vid may help you out.http://welding-tv.com/tig-welding-ov...weld-overhead/Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Aluminum Freezes quick, conducts heat away very quick, doesn't weigh much. I think it'll work fine.
Reply:Turn the trailer over. Dan
Reply:Yup you can tig Alu in all position
GMT+8, 2025-12-27 18:42 , Processed in 0.119297 second(s), 18 queries .
