Hello Everyone, I was going to build my own purge chamber was going to use 1/8 inch aluminum 30x30 with a plexi glass top kind of like a sand blast cabinet. Not being cheap just cant afford the real deal as of now. Any thoughts- advice. Question 2 has anyone used any aluminum tape for sealing pipe during purging is it the same as furnance tape? Thanx Dale
Reply:Originally Posted by powerHello Everyone, I was going to build my own purge chamber was going to use 1/8 inch aluminum 30x30 with a plexi glass top kind of like a sand blast cabinet. Not being cheap just cant afford the real deal as of now. Any thoughts- advice. Question 2 has anyone used any aluminum tape for sealing pipe during purging is it the same as furnance tape? Thanx Dale
Reply:Just about any tape would work, your not dealing with BIG pressure..... Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Ok im going to show my newbness. I understand what a purge chamber is but in what situations would you need such a box? I understand purging the back side of tubing, just not the need for a box to work in.
Reply:Some parts, mostly semi-conductor parts are better protected when welded in an atmosphere free of oxy...... Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Originally Posted by Jr_vw2Ok im going to show my newbness. I understand what a purge chamber is but in what situations would you need such a box? I understand purging the back side of tubing, just not the need for a box to work in. |
