the question of angular distortion during multi-layer welding
发表于 2021-8-31 23:17:03 | 显示全部楼层 |阅读模式
when the multi-layer is operated on  butt welding of plate  ,the multi-layer is 3 in here. i want to know the angular distortion is the largest value accur in backing layer or filler layer .
Reply:Originally Posted by edisonwangwhen the multi-layer is operated on  butt welding of plate  ,the multi-layer is 3 in here. i want to know the angular distortion is the largest value accur in backing layer or filler layer .
Reply:Originally Posted by SuperArcIt's very simple.  The diaphragmula coupled with the sipselocuator of the rebuttable presumption factor of 1, changes as velocities cubed by the cosine react to the temperature increase.
Reply:Originally Posted by MinnesotaDaveThat's an inappropriate use for the cosine....amateur....
Reply:Wang- Your translation does not make any sense. I don't know if I can explain it better than Superarc but ill try. I think you are trying to ask about warpage when welding, and if its the first pass or second layer In a three pass tee joint that will give more distortion? Basically, the more heat you put in the more it will warp. It warps upon cooling, it shrinks. Its going to bend in the direction of the side you weld when it cools. "the hot side is the short side" When I am making a Tee joint and I don't want it to warp ill pre-bend the plate by clamping a length of filler rod under it.Nothing Ever Got Done By Quitting, Never Give Up.
GMT+8, 2025-12-27 18:51 , Processed in 0.098993 second(s), 18 queries .
