Window/elevator gate racks
发表于 2021-8-31 23:16:53 | 显示全部楼层 |阅读模式
I was tasked with building a set of free standing racks that would hold some old windows and elevator gates. Here is what I came up with...I wanted to make them user friendly, thus the uprights are removable via pull pins for ease of unloading the gates and windows.Everything in 304L stainless. The uprights are 2" x 3" x 3/16" wall. Yes, they are quite heavy when assembled.I destroyed a carbide blade in the process so I need to get that repaired and sharpened. I don't know what I did wrong but I need to figure it out. The stainless blades aren't cheap at $230 a pop.Cheers,Marc
Reply:Marc... You need to work on making your post user friendly. Resizing and reposisionning your pictures would help greatly in this.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:No problem. I posted using the tapatalk app. The photos should be smaller? The app only allows 3 sizes I chose the medium size. I'll try the smaller size on the next go-round.
Reply:They look fine to me.
Reply:Pics as I see them are all over the page...resize??  Smaller may be better (pictures only)
Reply:Okay, here they are posted at the smaller size... By the way, thank you for letting me know.
GMT+8, 2025-12-27 18:42 , Processed in 0.108657 second(s), 18 queries .
