best way of cutting pipping for a turbo?
发表于 2021-8-31 23:16:51 | 显示全部楼层 |阅读模式
whats the best way to cut pipping for a turbo system? ive heard chop saw others have said band saw... input appreciated.If the conversation isn’t money, then I’ll see you later.
Reply:Chop saw or band saw.You didn't build that.'85 Miller AEAD-200LE
Reply:Originally Posted by anickodeChop saw or band saw.
Reply:If your asking what is cleaner you sure your ready to tig weld pipe?Miller Pro 300 SS w/ cat Miller Bobcat 250Miller Diversion 165 Miller 211Miller Xtreme 375Miller 12vsMiller Dynasty 200 DX Miller Passport Plus w/ Spool GunMiller 30a spoolmaticLincoln AC225 Buzz Box VictorMathey Dearman - H&M
Reply:Originally Posted by grindelIf your asking what is cleaner you sure your ready to tig weld pipe?
Reply:A good band saw will work the best. I always score pipe with pipe cutters then port a band itMiller Pro 300 SS w/ cat Miller Bobcat 250Miller Diversion 165 Miller 211Miller Xtreme 375Miller 12vsMiller Dynasty 200 DX Miller Passport Plus w/ Spool GunMiller 30a spoolmaticLincoln AC225 Buzz Box VictorMathey Dearman - H&M
Reply:An abrasive chop saw makes a messy cut, but the type with a blade will cut nice and clean (they're extremely loud though).  I'd say go with a horizontal band saw, it'll make a good cut and you wont need hearing protection to use it.TIG - Miller Syncrowave 200Plasma cutter - Miller X-treme 375Round column mill - RongFu 31
Reply:Originally Posted by MOE1im just wandering which would leave a cleaner cut? would i have to clean up the end a little after i were to cut it.
Reply:cool thanks guys!If the conversation isn’t money, then I’ll see you later.
Reply:4" zip blade. Easy to maneuver and the least expensive way to cut / trim thin tubing.Lincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
Reply:Chop saw w/ metal blade.  Can't do a lot of cuts in the middle of a radius on u-bends if you're using a band saw.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Band saw or Metal cutting chop saw.
Reply:I've had luck with a vertical bandsaw on thin-wall stainless, especially U and donuts. It's hard to get vices to hold exactly where you need when you're messing with mandrel bends.Miller: 200dx, Bobcat 225, Passport, Powermax 45, Milwaukee: Dry Saw, MagDrill, grinders
Reply:Doesn't really matter as long as you clean it up when the cut is done.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:i was seeking the answer to this question last spring. I bought one of the Dewalt chop saws with the metal blades....shortly thereafter i bought a nice bandsaw. You can't be with either if you really want to do some work, but the chop saw will get you a long ways. i found mine on amazon, seemed to be the best deal at the time.
Reply:i do this all the time ! i use my vertical bandsaw . becareful using a chopsaw .when you cut thrue mandrel bends in TUBING in will pinch the blade and it might get ugly if it pinches the chop saw blade but the band saw cuts it very nice and controllable . you just have to deburr with a belt sander and i use my die grinder to do the inside. just make sure your cuts are perfect or sand them perfect and welding is easy
Reply:Originally Posted by anickodeif you have to ask that, you're DEFINITELY not ready to TIG thinwall pipe.
Reply:Originally Posted by claymans13How is he not ready to weld simply from asking a question about which saw would make a cleaner cut? That's like me not being allowed to drive because I want to know if a 4 cylinder gets better gas mileage than a 8 cylinder.Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
Reply:Originally Posted by anickodeIt's not the asking what will give a cleaner cut, it's this part:that says it all.  If you're ASKING as to whether or not TIG welding will require any material prep after cutting, you're probably not ready for an advanced project like turbocharger piping.
Reply:Originally Posted by MOE1you need to pipe down... run your welder, not your mouth!
Reply:turbo charge plumbing is made from tube not pipe
Reply:Originally Posted by demon1018turbo charge plumbing is made from tube not pipe
GMT+8, 2025-12-27 18:41 , Processed in 0.111110 second(s), 18 queries .
