John Deer Generator Vent modification
发表于 2021-8-31 23:16:47 | 显示全部楼层 |阅读模式
I relocated the vents on this generator using aluminized, mandrel bent tubing. It was a bigger challenge than i thought. i did the hot work away from the tank. I must have bolted and unbolted the system about 1000 times! But i won the battle. Check it out...
Reply:Nice work!! Bet you feel better about taking your time and doing it right tho?
Reply:Yea, this is my side job so i basically just have tuesdays to start and finish jobs, the pressure makes me work faster than usuall but i always take time to do the job right.Doin stuff right and fast is stressfull, but i enjoy doing it...
GMT+8, 2025-12-27 20:23 , Processed in 0.194122 second(s), 18 queries .
