welding truck
发表于 2021-8-31 23:16:46 | 显示全部楼层 |阅读模式
My other big project that I have been working on.This is getting posted here instead of under the thread welding rigs cause the welder isn't on it YET!!!!! Should happen this week though.Started with a straight Bradford flatbed, modified, built and added all the rest. The lead reel reels in the second set of pics will go on after I drop the welder in place.
Reply:and a few more:
Reply:Nice rig!I think the only thing I migh criticize is how the vise hides the right tail/brake/turn signal.What's the stubby red pressure can on the right? Is that Propane or Chemtane (propane with an ad-mix)?-MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:" I think the only thing I migh criticize is how the vise hides the right tail/brake/turn signal.What's the stubby red pressure can on the right? Is that Propane or Chemtane (propane with an ad-mix)? "The tank is actually not stubby its about 45 inches tall, it just sits down with only a 1/3 above the deck. And yes its chemtane.On the vise I struggled with that, I am not a young guy and mounting it on the top deck was too tall and I can't work off of it it would have been about 4 feet up or so. I didn't want it on my hitch as I have a rollout wheel that fits into that. Which basically left me nowhere to put it. It only obscures the brake light, pics are problably not great but it can still be seen. A side note though is my headache bar has full lights in it so I actually have two sets of lights.I really fiddled with placement of it, the only other option would have been to really get agressive and remake the whole end of the bed ( which I considered and canned as too much work, not enough gain ); or make it so it hinged vertically and dropped down ( which after a couple of days dinking around with that idea I scrapped as it it really didn't layout properly and was too tall again or a ungodly mess hanging of the end of the bed. A last bad option was to conceal the license plate, which really would have covered it up and it couldn't be read.But I agree with you its not perfect it was a tradeoff, useability vrs placement.I will snap a couple more pics of it though you can't see the top brakelights, and I will open it up.
Reply:Here are couple of pics of vise/tailights showing my top lights and the vise opened up ready to use.
Reply:Looks great! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Yep!  Where space is limited compromises must be made!Admirable work!-MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Ever think about adding one more brake light out on the corners to make up for the one that's covered? Might not be too hard to do unless there's a lot of framing in the corners. Or shorten the vice mount so it only covers the back up light, they're not used much on the road, not as much as brakes.
Reply:Originally Posted by BistineauEver think about adding one more brake light out on the corners to make up for the one that's covered? Might not be too hard to do unless there's a lot of framing in the corners. Or shorten the vice mount so it only covers the back up light, they're not used much on the road, not as much as brakes.
Reply:Originally Posted by weldermikeI believe there's another set of lights up front behind the cab in the top right corner.
Reply:mount extra lights on the swing arm for the viceMillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC"I'd like to believe as many true things and as few false things as possible"
Reply:Would like to see a picture of the air swivel on the air hose reel. Thank you.
Reply:" Ever think about adding one more brake light out on the corners to make up for the one that's covered? "Its doable, but when I do it I will try to incorporate a backup mirror into it also." Would like to see a picture of the air swivel on the air hose reel. Thank you "Not tonight but I will put the handle in and and get a couple of pics of the reel.
Reply:Great job on the truck.  Leaving the vise 30* out from the bumper will expose the brake lite just fine.  My curious ... is that a real red tile roof in the background?  Like in the Mediterrainain (PIIGS) countries?  WTF?  I know, I know.  They like tile roofs and stucco in Payson too - protects from the dry air and forest fires!
Reply:"  is that a real red tile roof in the background "No its metal, metile is what its called. Still fire resistant.
Reply:Here are hose reel pics:
Reply:Any updates? Is that your purple heart? My dad was awarded one in vietnam.Ranger 305gMillermatic 140 AutosetDewalt Chopsaw2 grindersMy Fists
Reply:Nice looking rig!Just leave that vise sticking out the back like in one picture...that'll discourage the tailgaters and give you plenty of rear-end space in the parking lot!!
Reply:Great work.Just put a sign on the vise that says "See other brake light."  It'll be fine Last edited by jameslo; 09-30-2012 at 08:44 PM.
Reply:Sweet setup!Grant DupillIron Alterations LLCDel Rio, TX USAUpcycled Lighting, Furniture, Vintage, and Art from Steelwww.facebook.com/ironalterationswww.etsy.com/shop/ironalterationsMost Lighting Sold @ Montage Vintage, San Antonio TX
Reply:They would have my happy arse pulled over in less than 10 min with that brakelight covered.   Atleast around here.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I flipped the vise around and it doesn't coverup the whole light. I also have a neighbor who is retired state hghway patrol look at it and I am legal. in my state.
Reply:Nice looking rig!How hard is it to get that 100lb chemtane tank in its nook?
Reply:" How hard is it to get that 100lb chemtane tank in its nook?"Actually pretty easy, the pictures don't clearly show it but it has a door, and on of the top of the door two hinges with a flip down to match the bottle contour. So basiclly its pull trailer hitch pin, open the door and flip the top. Inside it has a piece I made which looks like a cross between a spoon and a two pronged fork, pinned to a motorcycle chain. The other side has a bolt that fits between the forks and tightens it down, and there is a hook hidden inside to hold the wrench for the bolt. The two chains fit into the side of the "box" by use of some "T" bolts I made and I cut T slots into the sides of the box so the chains just pop out, but tighten into the slot when securing the bottle.The bad tank is the oxygen, I need to pull the chemane out to fit the oxy bottle into the rack. Thats a busy corner BTW as there is a flip up compartment right up behind the bed and I have the same sized battery as my truck in the compartment ( all secured of course ) which is the welder battery. It all flush so it doesn't obstruct and the battery sits on top of the short diagonal box right behind the cab.Without major modes to the headache rack the oxy is just what it is, I already cut the side of the headache rack back six inches to make it all fit but didn't want to go more as it would get flimsy. If I had built the rack from scratch it wouldn't be that way BTW.
Reply:BTW I have the welder up on board now and I will get some pics of it on the truck. I still haven't mounted the lead reel yet, as I have: 1. been super busy working 2. need to isolate the ground from my truck on the lead reel 3. I am still doing some work on the welder the idle is set too low. Work just keeps getting in the way of my projects though.
GMT+8, 2025-12-27 18:42 , Processed in 0.102669 second(s), 18 queries .
