Brewing stand
发表于 2021-8-31 23:16:46 | 显示全部楼层 |阅读模式
Sent from my ADR6400L using Tapatalk 2 Attached ImagesMiller diversion 165Miller mig 211Hypertherm pm 30Milwaukee 6230 14 inch chop sawMd 45 mag drill (RIP; fell on its head)New MD 45! Thanks to the esposa!Finally got an O/A setup
Reply:Holy overly complicated batman!Why didn't you just mount the burner to the main stand? Also, why is the feed arm (?) going through the corner of the lower stand? I would have just mounted the burner a little lower so that the arm fit under the side  support. and had the angle sections like you have on the larger stand to hold the burner.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Good thoughts! I wanted the burner unit to be useable for a different stand theoretically. I could have put supports for the burner on the corners so the arm extended between the legs, that would have been easier!Miller diversion 165Miller mig 211Hypertherm pm 30Milwaukee 6230 14 inch chop sawMd 45 mag drill (RIP; fell on its head)New MD 45! Thanks to the esposa!Finally got an O/A setup
Reply:some good friends of mine are actually starting a brewery based on their home brew success so I've seen them go through several different brewing rigs. The latest rig took up the better part of a 14'x6' trailer with the kettles and stand. Firmenters arive tomorrow at the brewery.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Hi ThorsHammer,Are you planning to control the temperature between the first steps? How about filters, tranfer pumps, whirpool, cooling?Ten years before I made my own equipment, so if you think I can help do no hesitate to PM.Best regars and very good luckMauricio
Reply:Eliotmay,same thing for you, best regards!!!!Mauricio
Reply:nice work enjoy brewing you will have a blast and spend a boat loadDonnelly Small Engine & WeldingFoley AlabamaLincoln 225 TigLinoln 215 migHypertherm Powermax 65Ellis 1600 sawEllis 6000 belt grinderJD2 Model 4 tubing benderAtlas  12"X54" metal latheLots of large hammers
Reply:I'm not a brewer, just seen the different set ups. I'm the gofer that gets paid in tasty libations.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:I'm with thorshammer, I just drink the beer and do the weldingMiller diversion 165Miller mig 211Hypertherm pm 30Milwaukee 6230 14 inch chop sawMd 45 mag drill (RIP; fell on its head)New MD 45! Thanks to the esposa!Finally got an O/A setup
Reply:Neat!  A very neat stand!
GMT+8, 2025-12-27 18:43 , Processed in 0.106861 second(s), 18 queries .
