Firewood Rack (Pipe)
发表于 2021-8-31 23:16:45 | 显示全部楼层 |阅读模式
My brother ask that I build him a firewood rack that would hold at least a 1/2 cord of wood. I had this 2 3/8 OD X 3/16 pipe and 1/4 plate for the feet. I decidied to try building it with the pipe and saddle cut the fittings. First time to ever saddle cut pipe (used bandsaw). I used a Miller 212 machine. It is level and square enough. I didn't any feet in the middle due to the area he is planning on putting it. There is very little give there anyway but he can always put a block in needed. Top of pipe are still open, deciding what to put there.Rack is 8' long and 5 1/2 tall. Attached ImagesMillerMatic 212, Lincoln Precision TIG 225, Hypertherm 45XP
Reply:Very nice. I think it will hold a lot of lbs!!Dave ReberWadsworth Ohio
Reply:Nice work! Isn't welding a great thing?Miller diversion 165Miller mig 211Hypertherm pm 30Milwaukee 6230 14 inch chop sawMd 45 mag drill (RIP; fell on its head)New MD 45! Thanks to the esposa!Finally got an O/A setup
Reply:Very good. I've been thinking about building one of those myself. Thanks,SteveJunkYard Tools .com
Reply:Es Bueno!There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Looks good!  Beats the heck out of T-posts.  Best thing is keeping the wood off the ground...no rot, termites.
Reply:Thanks for the replies and yes, welding is a great thing. Fustrating at times but that's part of the challenge.MillerMatic 212, Lincoln Precision TIG 225, Hypertherm 45XP
Reply:I'm honestly surprised that no-one has insisted that you need gussets on it to support the load. LOL. That being said, I might suggest center supports. there will be a lot of weight in the center of that span.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Nice, man.(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah:  Go Big Red!   (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
Reply:You pulled off a strong stand!
GMT+8, 2025-12-27 18:41 , Processed in 0.175768 second(s), 18 queries .
