I own welding machine MIG ESSETI QUERY 350 K synergic system pulser. I also have esseti controller, but I do not have any instruction manual. I want to know if anyone could help me in finding a manual or to give me some instructions on programming and handling the machine for different materials and wires. Please help me. It's urgent! Attached Images
Reply:For mild steel set the dial to num 3 and put the red button on 4.For aloominumm put the dial to ALL and the red button on max. weld it like you own it
Reply:Let me guess, you and the welder are not from Indiana, are you??!?!!!Try 3-4 on the speed, 75% on the heat to start, then adjust the speed a little at a time. Then, adjust the heat if you need to.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:Hii have a manual for sale on ebay for this welder ebay item 200723192103would also be intersted to purchase the control if it's for sale ?Cheers |
