Flux Core wire question
发表于 2021-8-31 23:16:34 | 显示全部楼层 |阅读模式
I used .035 flux core wire from Hobart and ran out.  I want to get some.035 lincoln flux core wire.  Which one of these is recommended?http://www.amazon.com/Welding-Wire-N....035+flux+corehttp://www.amazon.com/LINCOLN-ELECTR...lding+wire+035Where do you recommend I buy it from?Thanks,-Gary
Reply:Those are both the same - zoom in on the spool.The Lincoln NR-211MP is just Lincoln's name for AWS: E71T-11 wirehttp://www.lincolnelectric.com/asset...P/c3200010.pdfDave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Thank you.
Reply:They are the same thing, NR-211MP.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Believe I saw the same wire at Home Depot today for about the same price.Jerry30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Not sure if this is a good place to ask but some where on the forum I read that E71T-11 is suitable for multiple passes where E71T-GS is not. Could someone give a little more detail.  Thanks.
Reply:Yes e71t11 is multipass all position wire. e71t-gs is single pass all position. I think the GS has more deoxidizers in it too but not 100% sureOnly problem with buying wire online is shipping costs actually make it more expensive than buying it locally. Home Depot sells that Innershield so if thats what u want and have a store in town just get it from there. If u caan get a good price online with free shipping then great. I have to order Hobart wire because no one sells it here. Even my LWS only stocks Forney brand unless I want to order it from them. If u dont mind the GS wire then u can get a good deal on wire from HTP America and they even have twin packs and stuff and I think they have Free shipping on orders of $50 or more. Never used there wire myself. If u are planning on running shielding gas and need solid wire than HTP would be great since there shouldnt be too much a difference between the same spec solid wire from different vendors.HH140---------------------------https://www.facebook.com/brandon.pike.9
GMT+8, 2025-12-27 20:25 , Processed in 0.225018 second(s), 18 queries .
