2012 Pipeliner 200D Trouble
发表于 2021-8-31 23:16:33 | 显示全部楼层 |阅读模式
I have a 200D and have to turn up a hole gear to get it to burn 3/16 & 5/32 close to wright. Anyone know anyone else having troubles and what they have found going back to the sa200 for know. any help is greatly appreciated.
Reply:Could you provide some more details?  I don't really understand what the problem is. Are you having to raise it a gear going from 5/32 to 3/16 or are you having to run them a gear higher then you used to?
Reply:Let me guess that this machine is new to you. Some of these machines just weld that way. You don't have to put it in max to burn a 3 do ya? Hotpass about 240range at 100 with a 3 or 70 with a 5. 190 is too cold to hotpass with a 3? Sounds about like mine
Reply:Originally Posted by steven325Could you provide some more details?  I don't really understand what the problem is. Are you having to raise it a gear going from 5/32 to 3/16 or are you having to run them a gear higher then you used to?
GMT+8, 2025-12-27 18:52 , Processed in 0.113890 second(s), 18 queries .
