built a rack for a quad.
发表于 2021-8-31 23:16:28 | 显示全部楼层 |阅读模式
So I had a guy at work want a rack built for his quad. He left me free to design as I wished. Within the following guidelines, must be: lighter, narrower, and higher. I asked him if it was cool that i use this project to practice TIG welding on, and its not my strongest process. his response, was you got my requirements you do as you wish from there. notice in the befor pics, of his previous setup. its just an SUV hitch mount rack. he used a 1.25 to 2 inch adapter from the Polaris receiver to attach this rack. It drags on everything by the looks of it. I asked about load capacity, and he said 5 gal of fuel and a small 6 pack cooler. i asked why his rack was bent. he said "i got it that way off craigslist." without further hold up here are the pics. Attached ImagesOffering CNC Plasma cutting and welding projects.Follow me on facebook https://www.facebook.com/nobigdeal.fabSupport those that support WW.
Reply:the thing came in at aprox 2/3 the weight 10 inches narrower, and 20 inches higher. its mounted under the "bed" of the quad, as well as the factory reciever. the thing will hold my weight jumping on the thing. it should be plenty for his 5 gal of fuel and 6 pack cooler. (espically since i know it will be carrying more) Attached ImagesOffering CNC Plasma cutting and welding projects.Follow me on facebook https://www.facebook.com/nobigdeal.fabSupport those that support WW.
Reply:i know my TIG welds are not that great, but given the warning and received approval, i went with it. its the only thing i wish i had not done. as my MIG welds look so much better. but how am i going to get better if i don't do it. (although not having a foot peddle, and it being lift start did not help) the welds are clean and solid welds. the only thing is the consistency of the dimes is not there. but in time ill have it down.Offering CNC Plasma cutting and welding projects.Follow me on facebook https://www.facebook.com/nobigdeal.fabSupport those that support WW.
Reply:That's a great rack you built.  I also think your welds look good.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:The rack looks very nice, I like the way it sits up higher as well as the all around construction of the build, much more practical.What ga tubing is being used? looks like maybe 14-16ga?? also what type of filler wire did you use?-Bill
Reply:It's 16ga and was done with 1/16 ER70s6Thanks for the compliments. I was really happy with the outcome. I will be starting on the front bumper this afternoon. Hopefully I'll have pics up of it in a few days.Last edited by ★ NoBigDeal Fab ★; 10-07-2012 at 01:42 PM.Offering CNC Plasma cutting and welding projects.Follow me on facebook https://www.facebook.com/nobigdeal.fabSupport those that support WW.
Reply:get that powercoated and it'll look better than shop bought, well done
Reply:Looks Real good!!!!
Reply:Originally Posted by Gerry1964get that powercoated and it'll look better than shop bought, well done
Reply:Originally Posted by TIGger305Looks Real good!!!!
Reply:Very nice design! Good job.MillerMatic 212, Lincoln Precision TIG 225, Hypertherm 45XP
GMT+8, 2025-12-27 18:53 , Processed in 0.071112 second(s), 18 queries .
