Currently Building an Aluminum Cart, any aluminum casters?
发表于 2021-8-31 23:16:27 | 显示全部楼层 |阅读模式
Are these hard to find?  Where are you guys buying them?  I'm new to sourcing metal and materials so I need some guidance.  Thanks!MM211 w/Spoolmate 100
Reply:Just buy some that bolt on.I've never seen aluminum casters but I've never looked either. I made a aluminum cart and I just bought some steel base casters that bolted on.
Reply:Cool, thanks for the idea!!!MM211 w/Spoolmate 100
Reply:so why do you need aluminum casters?welding isn't always the right way to fasten parts together lolWelding/Fab Pics: www.UtahWeld.com
Reply:So what I ended up doing is buying casters and bolting them to aluminum plates, individually.  I supported the plates with small pieces.  Turned out well, I think.  lol.  Just need to add a handle and a cage for the gas.  It only weighs 10lbs but is supporting around 150+!  Awesome!!!!  I love itMM211 w/Spoolmate 100
Reply:Is that tank secured to the cart somehow, or just sitting there?Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Originally Posted by FexalIs that tank secured to the cart somehow, or just sitting there?
GMT+8, 2025-12-27 18:52 , Processed in 0.101949 second(s), 18 queries .
