Lincoln SA200 Project
发表于 2021-8-31 23:16:27 | 显示全部楼层 |阅读模式
Well a few months ago i saw this old SA out in someone's side yard in the weeds. I stoped in and asked if he would sell it. He said $400 and its yours. I came back the next day with $400, gas and a battery. Oiled everything up and she started right up and welded good!!!! I took her home and started to take it apart.Here are some pics and the story behind the SA200 F-163. Enjoy and let me know what you think. Thanks for looking!Lincoln SA 200 Lincoln Idealarc 300/300 TIG
Reply:Did some work on the hitch.The tear down and repaint!New/Used tires for $40Lincoln SA 200 Lincoln Idealarc 300/300 TIG
Reply:Some new parts!Time to shell some corn.New Paint!!!New wiring.New dog Lincoln SA 200 Lincoln Idealarc 300/300 TIG
Reply:looking good!OK HERE IS WHERE I NEED. I cant since to get spark. I check everything on here about what to do and i just cant get it. Any have any ideas? OR is there any one around Ann Arbor area that i could take it to or come look at it on this site? I will pay out if we get it running! But everything looks good from what i can see and know about these. Lincoln SA 200 Lincoln Idealarc 300/300 TIG
Reply:That was an excellent "find".Lincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
Reply:Well, in the beginning it ran so it's probably just an issue of making sure the timing marks are properly aligned. I'd remove the mag and clamp it in a vice. Rotate the input lugs and see if it will fire. If it won't fire, begin to check your timing marks on the small gears.It could just need to have the points re-adjusted also.Thanks,HoboLincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
Reply:Skip the grounding cable on it, sucks to do it, but keep trying until your hands feel it. Did that on mine, heart skips a beat but I know I have spark.Bruce
Reply:Nice find, nice restoration and nice puppy.Leo
Reply:Pass a grinder over the jack where it says made in "that bad place". That has no right being on such a fine machine. Nice and pretty. take it back and ask if he wants too see it. see if he crys like a baby.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:Originally Posted by dumb as a stumpPass a grinder over the jack where it says made in "that bad place". That has no right being on such a fine machine. Nice and pretty. take it back and ask if he wants too see it. see if he crys like a baby.
Reply:Very nice.Make sure this grounding strap isn't making contact with the breaker points backer plate.Did you clean/adjust the points?  Double check them as hobohilton suggested.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:If you live in an area where rust can be prone, I would recommend redoing all your electrical tape wrapped connections for soldered with heat-shring to protect against potential corrosionI break things for a living...
GMT+8, 2025-12-27 18:51 , Processed in 0.133994 second(s), 18 queries .
