Toyota tacoma rock sliders
发表于 2021-8-31 23:16:24 | 显示全部楼层 |阅读模式
I made a set of rock sliders for my buddy's truck. He already had the main rail welded to his truck but it was not really protecting the truck body. So i made these and welded them on for him.Here are a few pics of the build.TotlandDesign
Reply:One last pic.Let me know what you guys think.TotlandDesign
Reply:I hope you disconnected your battery before you started welding on your truck, otherwise they look good, are welded right to your rocker panels??Edit I read your intro scratch what I asked....Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:They look good,what size material is that?Millermatic 252Syncrowave 200Cutmaster 42
Reply:Good job. I like the design. but I prefer round tube for things like this. I have something similar on my ram. If its used as a step, can I suggest adding on a few pieces of expanded metal, as they become slicker than snail snot in august when they get wet or muddy. I just about face planted the door panel once at a car wash. but I did manage to bash my shin on the tube and split it wide open, when I fell. I then added the expanded metal. and its not a problem.Offering CNC Plasma cutting and welding projects.Follow me on facebook https://www.facebook.com/nobigdeal.fabSupport those that support WW.
Reply:The size of the tubing is 1.5"x1.5"x0.120 hrew. We originally wanted round tubing but I don't have a tubing bender. I actually like the bulky look of the square tubing though.Expanded metal  would actually be a cool design I think.Maybe I'll do that next time. Thanks for the input.TotlandDesign
Reply:I like this a lot!!  The square tubing is awesome, actually like it better myself!  I agree tho, definitely get some type of tacky material to put down.  If you someone is going to slip for sure.MM211 w/Spoolmate 100
Reply:Another small feature that can be handy, is that if they are strong enough to use as a jacking point, you can add stringer beads to the bottom of the tube, that way a high lift jack will have a ridge to catch on, and it won't slide off the step once it gets up to a sharp angle where it may slide. If that made any sence, if not I'll see about explaining it better.Offering CNC Plasma cutting and welding projects.Follow me on facebook https://www.facebook.com/nobigdeal.fabSupport those that support WW.
Reply:Here are the additions I put on my stock Wrangler Rubicon slidersThis was done with 1x2x.120On the JeepA work in progressMan this took some fit-up time.  Not a straight line to be found on the stock slidersAfter I was done and cleaning up, I realized that it would have been much simpler to cut some cardboard to match the curve, make the "legs" oversized, mark them with the template, cut once and be done.  Dohhhhh!Last edited by frieed; 10-11-2012 at 10:49 AM.MillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC"I'd like to believe as many true things and as few false things as possible"
GMT+8, 2025-12-27 18:53 , Processed in 0.081341 second(s), 18 queries .
