source needed for 3/8" x 3/16" solid stainless bar or rod
发表于 2021-8-31 23:16:09 | 显示全部楼层 |阅读模式
I need 3/16" x 3/8" solid rectangular bar/rod of any alloy of stainless (cheaper is better). My local metal shops have to order it and have it shipped UPS so i might as well order it myself but i have no idea where they are ordering it from.  Right now I am just prototyping so i don't need a full stick but if i have to i will happily order one. In the future i may need large quantities.ANY leads would be great. I am in Colorado but I am guessing this is going to have to be shipped from out of state as i have called most all Colorado distributors.I can make 3/16x1/2 work (kinda) and that is common, but it would work much better to have 3/16" x 3/8" or 5mmx10mm or 5mmx8mm...   Thanks in advance for the help, (i looked and looked for a place on this forum to put this question.  is there a better place?)Last edited by cadmus; 10-11-2012 at 11:42 PM.
Reply:www.gordonsteel.comhttp://www.gordonsteel.com/inventory/Stainless.htmIhave never done business with this company, just a google search fouind this compoany stocks the size you asked for.  3/16 x 3/8 seems to be an odd size.- MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:I checked:onlinemetals.comAmazon metalsmcmaster-carr...and no go.How long does it need to be?  Maybe you could order wider strip as needed, and cut it to 3/8" lengths.
Reply:Originally Posted by Mondowww.gordonsteel.comhttp://www.gordonsteel.com/inventory/Stainless.htmIhave never done business with this company, just a google search fouind this compoany stocks the size you asked for.  3/16 x 3/8 seems to be an odd size.- Mondo
Reply:Originally Posted by jakeruI checked:onlinemetals.comAmazon metalsmcmaster-carr...and no go.How long does it need to be?  Maybe you could order wider strip as needed, and cut it to 3/8" lengths.
Reply:Try these guys...http://www.admiralmetals.com/AdmiralMetals/?page_id=47...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterTry these guys...http://www.admiralmetals.com/AdmiralMetals/?page_id=47...zap!
Reply:If it doesn't have to be perfect why don't you have someone shear it off a piece of 3/16 sheet?
GMT+8, 2025-12-27 20:30 , Processed in 0.103122 second(s), 18 queries .
