Battery Door
发表于 2021-8-31 23:16:08 | 显示全部楼层 |阅读模式
Another one of the quickie fixes to get the truck on the road.  It didn't have a battery cover on the battery box.  This earned me a nice fat ticket on the original trip home with this gem 1/8 diamondplate, and some angle......................At least this is legal now   (batteries aren't tied down, but maybe the new lid will hide the fact )It's coming togetherThis engine is supposed to have 3 batteries (one sits on the other side of the cab), but 2 batteries is enough to fire it up in warm weather."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Here you go Sam.Don't click on this with kids in the room.Last edited by TozziWelding; 10-10-2012 at 09:27 AM.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Looks like it wouldn't be difficult to add a cross bar and a few bolts to hold those batteries down.  Why go half-way?Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Hope you put a nice piece of rubber over the batteries first samm, I have only ever seen one battery blow up, It vanished into a thousand pieces and showered acid everywhere, It was caused by a spark  from fitting a set of jump leads.The guy in the cab hit the starter button while I was waggling the crocodiles to get a good contact,He heard the band and couldn't believe his good spare battery had just vanished in to thin air!!Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:come on sam you know that no cover is a hazard the  dot is just keeping the road safe from tthe evil rich truckers. Yeah right. My baqttery box like that I used some scrap 3/8 b 2 flat and 2 bolt welded togeather to make the right length,i was out of threaded rod.Millermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:LOL at fudpucker video. stick a cheap floor mat to the underside of your cover with some of that cheap contact adhesive and be done with her. I like the battery box cover............man, I gotta watch it, I'm starting to catch myself checking my twypos.MLM
Reply:I have a mudflap on top of my battery's just as cheep insurance for no real reason to myself.    Its one that was gracefully removed when tire met curb in that lovely rom-com sort of way.     Plus should some craziness arise i can always use the mud flap for a secondary purpose.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-27 20:30 , Processed in 0.154664 second(s), 18 queries .
