Small Gun Modification..
发表于 2021-8-31 23:15:56 | 显示全部楼层 |阅读模式
I have no idea what this goes to or does and I am sure member 7.62x39 will chime in and tell ya all about it..Pics should be in order but there is no real order now is there??One more post.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Couple more pics..Welder set at 130? amps MAX..3/32" Red...045 309 filler..(Couple of dabs)..I get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:It's a bolt from a mauser(I think).they come with a bolt handle that sticks straight out. Many modify the bolt handle to this turn down style to make it less bulky and easier to use . Nice work
Reply:Originally Posted by gator9329Many modify the bolt handle to this turn down style to make it less bulky and easier to use .
Reply:I'm thinking Mauser as well, though I could be off.I have done this modification to MANY Soviet Mosin Nagant rifles for myself and some friends.You didn't build that.'85 Miller AEAD-200LE
Reply:But,,,,, just because it's called a bolt action doesn't mean you (the owner) actually has to use a bolt. Works for me tho. "The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Stripped-down M98 Mauser-type bolt body, being modified for a bent-bolt handle via welding (by zap).http://en.wikipedia.org/wiki/File:Ma...schluss-04.jpg  The best laid schemes ... Gang oft agley ...
Reply:Definately a mauser, would know that bolt anywhere.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Not sure why the owner wants a honest to god bolt on there, you can buy a ready to go bolt hande specifically for that shootin iron for a few bucks. we used to 10 or 12 of em in a summer Attached ImagesExperience is something you get right after you need it
Reply:I hope this answers your question about the bolt. Here's a pic with the handle installed. Zap did a real nice job on this. More on this rifle here http://www.gunco.net/forums/f300/mau...version-68913/I'll post a finished pic tomorrow Attached ImagesLast edited by 7.62x39; 10-01-2012 at 10:44 PM.Reason: typoJust a hobbyist with a Hobart handler 140
Reply:That's ah nice ah! City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Does this rifle have the Waffenamt?Last edited by Insaneride; 10-01-2012 at 10:32 PM.Reason: Sh!t bird
Reply:No Waffenamt stamp. Almost anything with one would have some sort of collector value. This is actually a 1937 Czechoslovakian VZ-24 (same as large ring Mauser)Just a hobbyist with a Hobart handler 140
Reply:Wow, that must have some collector value. Does it have some war trophy value or do you hunt with it?
Reply:NIce work zap. Did you make the knob also?
Reply:Originally Posted by InsanerideWow, that must have some collector value.
Reply:Love the Kevin Smith avatar!
Reply:Originally Posted by forhireNIce work zap. Did you make the knob also?
Reply:Starting out with a well used 1937 Czechoslovakian VZ-24 (Large ring Mauser)I blueprinted the bolt and receiver and mated it to a Numrich trapdoor trigger guard assembly. Then I inlet it and pillar bedded it into a Boyd's laminate stock. I re-chambered it to .308 Win.  using a 22" Shilen #5 contour barrel with a 1 in 10 twist. I cut off the straight bolt handle and fabricated one of my own, which Zap welded on for MeI drilled, tapped and installed a one piece scope rail, then assembled it using a Bold Optimal trigger, a Titanium firing pin with a speedlock spring and a sporter bolt shroud. I finished it off by adding a grip cap, recoil pad and swivels to the stock. Topping it off is a Simmons 4-12X44 scope and a Harris bi-pod. I fully expect this rifle to shoot MOA. Attached ImagesJust a hobbyist with a Hobart handler 140
Reply:Kick A$$!!!Just don't point that at me anytime soon....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Nice job as always ZAP, and sweeeet gun! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Really nice rifle, 7.62x39!Nice job Zap!I've thought about doing that to my Mosin, but I would just wind up buying yet another scope (that'd be worth more than the gun it's on)..Buy American, or don't whine when you end up on the bread line.
Reply:If anybody is interested, there is a step by step thread on the building of this rifle posted on my forum.http://www.gunco.net/forums/f300/mau...version-68913/Just a hobbyist with a Hobart handler 140
Reply:great job Zap ! 7.62; target shooter? should be 1"moa at about 800...happy plinking.
Reply:Bolt guns are a bit of a departure for me. Rarely do I start with a manufactured receiver. I usually make my own. I'm primarily an AK guy. This is typical of what I normally build. I bend the receivers up out of a flat. This was a demilled Yugoslavian M-92. I had to pin on a fake silencer in order to be long enough to be legal and naturally it has to be converted to semi-auto. I've built at least one of almost all the AK variants. Attached ImagesLast edited by 7.62x39; 10-02-2012 at 07:10 PM.Just a hobbyist with a Hobart handler 140Originally Posted by a1998z3great job Zap ! 7.62; target shooter? should be 1"moa at about 800...happy plinking.
Reply:Originally Posted by 7.62x39More of a long range tactical rifle
Reply:Probably the craziest one I ever built was this one. It's a M-1919A4 . belt fed, air cooled, 30 caliber Browning machine gun. (converted to semi-auto) Mounted on a modified German MG-42 anti-aircraft tri-pod Attached ImagesJust a hobbyist with a Hobart handler 140
Reply:Do you ever run across Russian made AK's or in particular a Spetsnaz version?  If you have a pic I would appreciate seeing one. ThanksNice work on the Browning.
Reply:Originally Posted by 7.62x39Probably the craziest one I ever built was this one. It's a M-1919A4 . belt fed, air cooled, 30 caliber Browning machine gun. (converted to semi-auto) Mounted on a modified German MG-42 anti-aircraft tri-pod
Reply:Originally Posted by InsanerideDo you ever run across Russian made AK's or in particular a Spetsnaz version?  If you have a pic I would appreciate seeing one. ThanksNice work on the Browning.
Reply:Originally Posted by zapsterGeeeee..That looks like what was left of the tree I took out for ya a few years ago in the background.....zap!
Reply:oops, double tapJust a hobbyist with a Hobart handler 140
Reply:Zap, I like this guy.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by TozziWeldingZap, I like this guy.
Reply:No questions, I just want moreDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by zapsterHe will be with us next week.....zap!
Reply:Originally Posted by 7.62x39I'll be there bright and early tomorrow morning. How do you take your coffee?
Reply:Originally Posted by zapsterHe will be with us next week..Got any gun questions?...zap!
Reply:Nice job on the M1919. I wanted a semi auto M60  for a while. Didn't have the cash for a real one, though the semis are almost as expensive. I never really got into the 30 cal Browning's, I preferred the 50's myself. I wouldn't mind one of the .30 cal spade gripped aircraft guns however..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:7.62x39 thanks for that interesting information.  Do you have a custom made ball turning tool to make those mauser handles? I would like to see it if its not proprietary or anything.ZAP, nice photography work. I mean your lighting and perspective are great. Thanks for sharing.
Reply:For the handle I just bent up a 5/16 X 24 bolt. The knob itself I bought from a gunsmithing supply house. I was going to make something myself, but for $6 I didn't even think it was worth my time, so I just went ahead and bought it.DSW,I have the plans for a spade grip for the Browning. It's on my list of things to do and I will get to it eventually. Right now I'm working on a bullpup design AK. Details here. http://www.gunco.net/forums/f43/aku-94-project-69073/Just a hobbyist with a Hobart handler 140
GMT+8, 2025-12-27 22:14 , Processed in 0.106963 second(s), 18 queries .
