Need Help With 2050 Solar 50 amp plasma cutter -
发表于 2021-8-31 23:15:53 | 显示全部楼层 |阅读模式
Hi everyone I was given a  2050 Solar 50 amp plasma cutter  and it dont work ......I can get a arc but its just a small weak arc ...any hints of where to start looking ....Thanks Jim
Reply:Try to find a manual for it. There may be troubleshooting guides in it.Other than that, open it up and check for loose connections. Maybe new consumables too.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Thank You  Gravel....I just found a  Owners Guide Instruction Manual I'll open it up and see if I can find something loose
Reply:Either a pilot arc relay or a pilot arc resistor...Jim Colt  Hypertherm Originally Posted by justski49Hi everyone I was given a  2050 Solar 50 amp plasma cutter  and it dont work ......I can get a arc but its just a small weak arc ...any hints of where to start looking ....Thanks Jim
GMT+8, 2025-12-27 22:21 , Processed in 0.103253 second(s), 18 queries .
