miller 350 p users questions expectations ??
发表于 2021-8-31 23:15:45 | 显示全部楼层 |阅读模式
well i got a 350p awhile back and have got to do a couple things but am finely  getting to do some practice on its true purpose aluminum with 5356  on 5052 from  063-.125 what im wondering from those that have had and used them for awhile what should be my expectations on thinner aluminum like 063  080and 090 5052  should i expect to be doing short 2-3 inch welds without warpage etc or should i expect more just like to get some info from real world users and want to make sure my machine is performing up to snuff350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:It is going to warp like a motha. Whatever the case you are running in spray the whole time. You could try a lite hotstart too, and keep the run as small as possible too. If you have the AlumiproXRgun you could try to run some .035 or .030 wire which could help. Good luck. Alum is all I use mine for. It is great.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
GMT+8, 2025-12-27 20:39 , Processed in 0.101238 second(s), 18 queries .
