Water hose diameter
发表于 2021-8-31 23:15:45 | 显示全部楼层 |阅读模式
Does anyone know what the inside diameter of the water hoses for a #20 torch is? Looking at pictures and videos, it looks like 1/4" but someone who has one would know better. Any help would be appreciated. kidtigger24  They think I’m crazy, but I know better. It is not I who am crazy. It is I who am MAD!
Reply:The tubing O.D is .281The tubing I.D. is .155The barb on the torch is .212 according to my measurements..Why do we need this info?...zap!Last edited by zapster; 03-23-2012 at 11:23 AM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterThe tubing O.D is .281The tubing I.D. is .155The barb on the torch is .212 according to my measurements..Why do we need this info?...zap!
Reply:Originally Posted by kidtigger24Does anyone know what the inside diameter of the water hoses for a #20 torch is? Looking at pictures and videos, it looks like 1/4" but someone who has one would know better. Any help would be appreciated. kidtigger24
Reply:Originally Posted by dave powelson....ummm, often (usually) the power cable line is larger than the water feed line--both carry waterto complete the circuit from pump-to torch-to pump.
Reply:C-K flex loc #20 silicone jacketed leads:.260 OD -outlet hose.340 OD-power line hoseBlackbird
Reply:Just for laffs I will measure mine tomorrow.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterJust for laffs I will measure mine tomorrow.....zap!
Reply:Originally Posted by kidtigger24Isn't that your stuff in the pictures? I know that is your 50lb piece of steel in picture 2. It works good as a hand rest, but damn is it heavy. Seems like I had to move it 50 times last time I was there. kidtigger24
Reply:Originally Posted by zapsterI am not too sure about that..(I have a spare torch head)..The O.D. of both tubes are the same but the ends are different..Kinda hard to tell from the pics but yes they are the same.....zap!
Reply:Originally Posted by brucerI cant believe your using Chinese calipers..
Reply:Originally Posted by kidtigger24Thanks for the info Zap! I'm starting to plan for my water cooler and don't want to use the huge ProCom pump that everyone uses.
Reply:Originally Posted by MikeGyverHere's my alternative to that pump, still working flawlessly http://weldingweb.com/vbb/showthread.php?t=58517
Reply:Dunno. Just about any model will work really. These pumps will shoot up over 200psi if you deadhead them, and also flow 1-3GPM open flow, which is WAY more than you need or could ever get w/o rupturing the lines first from the pressure required to do so. They're suited very well for the application. Look on ebay, they're cheap.Last edited by MikeGyver; 03-26-2012 at 03:49 AM.Welding/Fab Pics: www.UtahWeld.com
GMT+8, 2025-12-27 20:30 , Processed in 0.105390 second(s), 18 queries .
