A little painting and some welding on brand new bucket teeth
发表于 2021-8-31 23:15:39 | 显示全部楼层 |阅读模式
Today I did a bit of painting, welded a thumb pad on and put a smooth edge on a digging bucket
Reply:Why do they have it labeled a  7AKECUCHI when it only has 6 teeth?"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:That's a "T"...looks like a 7.http://www.takeuchi-us.com/www
Reply:I can't quite tell, but it looks about the size of the Takeuchi we has, around 15K. I hope the fixed booms are better than the extend-a-hoe booms were. We had to have ours fixed several times for cracks. Takeuchi  doesn't even offer that size machine in an extend-a-hoe last time I looked. Parts weren't available either. Only option besides repair was a new fixed length boom..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWI can't quite tell, but it looks about the size of the Takeuchi we has, around 15K. I hope the fixed booms are better than the extend-a-hoe booms were. We had to have ours fixed several times for cracks. Takeuchi  doesn't even offer that size machine in an extend-a-hoe last time I looked. Parts weren't available either. Only option besides repair was a new fixed length boom.
Reply:Can you give us the welding details?"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Holy teeth! Did that bucket come with the Shanks that tight?Miller Dynasty 300 DXMiller CST280Miller Maxstar 150 STH
Reply:Welds look good btw! Did you wrap completely around the plate for the thumb? I have seen some guys run from the dipper onto the plate leaving 1/2" or so on the top and bottom unwelded.Also,Did you weld that edge front and back?Last edited by Silverado; 10-25-2012 at 10:16 PM.Miller Dynasty 300 DXMiller CST280Miller Maxstar 150 STH
Reply:Originally Posted by Stick-manCan you give us the welding details?
Reply:Originally Posted by SilveradoWelds look good btw! Did you wrap completely around the plate for the thumb? I have seen some guys run from the dipper onto the plate leaving 1/2" or so on the top and bottom unwelded.Also,Did you weld that edge front and back?
Reply:Here's the back of the edge welded
Reply:Originally Posted by Firemanmike691/8 7018mr right around 100-110 amps on a Lincoln ideal arc dc-600 for both welding projects
Reply:Originally Posted by anickodeThat seems awfully cold for 1/8" rod, especially on that size material.  I have run that much current on 3/32" 7018.
Reply:Originally Posted by Firemanmike69That's what the meter on the welder said but who know if that's accurate, the puddle didn't look cold when I was welding and the finished weld doesn't look cold, to me at least
Reply:Originally Posted by Firemanmike69Here's the back of the edge welded
Reply:Originally Posted by weldermikeThis weld will break tho bud, cheers on filling in a void but  not with that abuse!
Reply:What will probably happen is the machine will sit in our yard for a week after it was a "big rush" then the customer will call the rental agent who will tell my boss to tell me they don't want the edge welded on it and they decided they have to have a thumb on the machine and the rush starts all over again. Yea seriously silverado, it's only actually 1 more tooth than a standard digging bucket but it really makes them look jammed in there
Reply:Those plates are always temporary seeings that those are new teeth they just cut them off and tack them back on as neededNow if these were old teeth welded on a cutting edge that would be more permanent but its faster to quick change buckets these days than to change teeth..If the machine is so equippedBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Originally Posted by killdozerd11Those plates are always temporary seeings that those are new teeth they just cut them off and tack them back on as neededNow if these were old teeth welded on a cutting edge that would be more permanent but its faster to quick change buckets these days than to change teeth..If the machine is so equipped
Reply:Originally Posted by Firemanmike69That weld is just to hold it on if they use it to push dirt away from the machine with that edge, it will hopefully hold untill next week when the customer returns the unit from rental and I have to cut the cutting edge off lol
Reply:Originally Posted by DSWWe looked at getting a shallow super wide bucket with a straight edge on it just for grading. Boss was looking at either a custom  5' or 6' wide bucket for just that purpose. We used a 36" bucket for general digging and had a 24" and 18" bucket we almost never used, that came with the machine. Can't remember if we had a 12" bucket for that machine or not.
Reply:5 or 6 Foot wide bucketOnly time i seen that kind of thing was on a Gradall 1000 it was more like a box scraper they graded the underside of bridges for the concrete slab to be poured on and slopes like thatBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:I'll have to remember to look on Monday and see what the widest bucket we have is
Reply:Would this foot the bill DSWBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old TruckPretty sure the bucket on this guy was 5 foot or at least awful close
Reply:Car wash anyone       http://www.facebook.com/video/video....40016239368808Backed my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
GMT+8, 2025-12-27 20:39 , Processed in 0.103535 second(s), 18 queries .
