removable leads for Lincoln tombstone
发表于 2021-8-31 23:15:37 | 显示全部楼层 |阅读模式
Thanks to Nathan for the idea ( http://weldingweb.com/vbb/showthread.php?t=90691#12 ) .  I decided to go with size 50 Dinse instead of Twecos and used the factory hole locations.  Paint is currently drying where I went back and touched up the cut edges (original holes were .680" - new ones are 1.194" plus the little anti-rotation keyway).  Receptacles are Lenco LDPM-50 and the plugs are LDP-50M.  Going to reassemble tomorrow. Attached ImagesLast edited by dbotos; 07-14-2012 at 10:26 PM.
Reply:That'll be nice, you can come and do ours too!! City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Looks factory made, nice job.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Nice job.I wanted to do the same to my T-bolt.Couldn't get those connectors at my lws.I ended up cutting leads off short and puttingLenco female inline connectors on.Maybe when I take cover off to clean and lube I'll add panel mount connectors.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:GREAT job.  What paint color/code?TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:dbotos--nice job!  It's really cool to take someone like that and customize.  I would like to do soothing similar with my MIG and TIG machines.  Do you happen to know of the DIN 50 female connector part no?  I have the exact same male connectors now.   Thanks for posting it.
Reply:Very nice, but why Dinse vs. Tweco? Around here Tweco's are the most popular, on the larger machines."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by 200mphbusa...  Do you happen to know of the DIN 50 female connector part no?  ...
Reply:Thanks for the compliments.  I got her put back together this morning.  I went with the Dinse standard since I've got two other machines that have them.  Machine code is 10426.  Not sure what the correct paint for it is - I just sprayed some Banner Red Gloss Krylon in a cup and brushed it on the raw edges.  It's not a perfect match, but the body of the receptacle covers it up anyway.  Going to go test it out in the hot sun now...  Attached Images
Reply:One last finishing touch - color coded the work clamp connection.  Also put it on a little dolly to wheel it around (i.e. 12 x 18"  piece of 3/4" MDF with four casters screwed to the bottom).  I'll have to make a proper cart for it one of these days with storage for electrodes and other goodies.   Attached Images
Reply:Very Impressive... Nice post.. Really shocked to see this pis..Look like made any expert...anti plagiarism website
Reply:Nice clean install.  It looks way better this way.Miller Dynasty 200 DXBuildPro TMA52238 (38" x 22")Miller MP-10 & Jackson Nexgen EQC20 Ton Press & Swag HD Press Brake
Reply:Looks like you pulled it out of a box that way from the store. Good job.Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Thanks.  I would say it'd be cool if they came this way from the factory, but with these being lower cost / entry level machines, it'd probably add too much to the cost.  Fortunately, though, it's a pretty straightforward DIY.  Plus you can make whatever lead lengths you want.
GMT+8, 2025-12-27 20:39 , Processed in 0.077885 second(s), 18 queries .
