Stainless fabrication companies
发表于 2021-8-31 23:15:34 | 显示全部楼层 |阅读模式
Hope this is in the right section, if not scold me and relocate as you see fit Trying to find stainless fabrication companies around the central Pennsylvania area. May be moving, and if I do,I would like too stay in the same line of work I'm in now.If you don't want to share a name publicly, feel free to pm me.Thanks to all in advanceSent from my SGH-T989 using Tapatalk
Reply:hmm I don't know any off hand, where would you be moving in PA?Millermatic 211Miller Syncrowave 350lx with cooler and tigrunner Thermal Dynamics cutmaster 811955 National Cylinder Gas O/A setup with original patina
Reply:im from pottsville pa which is northeastern     where do  you plan on moving to?
Reply:Originally from Denver/ephrata area, and have family in wolmelsdorf (sp) looking in that area. But at this point, it's all up in the air and open for discussionSent from my SGH-T989 using Tapatalk
Reply:womeldorf is bout 35 miles south of where im at . http://sanprosys.com/ in litiz not far from ephrata . http://www.freestech.com/index.html in robesonia close to womelsdorf
Reply:alot of other types of welding jobs up this way too
Reply:Originally Posted by puty72womeldorf is bout 35 miles south of where im at . http://sanprosys.com/ in litiz not far from ephrata . http://www.freestech.com/index.html in robesonia close to womelsdorf
Reply:Ah Pottsville, home of Yuengling beer.   Been quite a while since I've had the opportunity to swill one of those.   I grew up in the Danville area.
Reply:Originally Posted by 4956Ah Pottsville, home of Yuengling beer.   Been quite a while since I've had the opportunity to swill one of those.   I grew up in the Danville area.
Reply:yea its a toss up with pay scales up this way
Reply:Originally Posted by dcoffmanjrI take it you've moved across the Mississippi river? Since I've moved to Arkansas, I've met several guys that reminisce of yuengling. Personally wasn't a fan of it, but to each their own I suppose.
GMT+8, 2025-12-27 20:38 , Processed in 0.435232 second(s), 18 queries .
