Stick electrode selection help please
发表于 2021-8-31 23:15:28 | 显示全部楼层 |阅读模式
I have a Lincoln Squarewave 175 I picked up awhile ago and have been using it mostly to TIG smaller (much cleaner) things.  My next project is going to be to build a grader drag rake to resurface the gravel part of my driveway.  I have some angle iron and a bucket of used railroad spikes that are to become the tines used to break up the surface of the gravel.  Question - since this doesn't seem like it will be a lot of fun with TIG, can anyone recommend the proper electrode, polarity, and diameter to tackle this?  I have some stick experience, but am by no means an "expert".thanks!Scot
Reply:If it is really dirty I would use 6010 dcrp if clean7018s dcrp either in a 1/8' rod. My prefference would be to make it clean as possible and use the 7018s.
Reply:Yep, do the clean up first, then get after it with the 1/8 7018 @ 120-130 amps. Hope your angle is at least 1/4" thick or more. If not then it probably won't hold up to being dragged thru the gravel for very long. Post up the pics as you go and finished project, I may want one for my driveway.
Reply:Thanks for the input guys!  I'll post up some pix in the project section when it's done.
Reply:Out of idle curiosity would anyone consider hard facing the spikes on the side that gets dragged through the gravel?  I have no idea what kind of steel railroad spikes are made of or if wear is an issue.  wouldn't be if it's just one guy's driveway, but half a summer later all the neighbors have come by to borrow it?
Reply:Hardface rod is typically pricey compaired to 7018,  I'd balance the extra cost  with time in service.  Maybe just build it back up with the 7018
Reply:7018 DC+ (reverse) polarity is the rod for the job as others said.1/8 at 125 amps is what i run or 3/32 rod at 85 amps.Last edited by snoeproe; 03-28-2012 at 07:55 PM.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Originally Posted by Dan FS71Hardface rod is typically pricey compaired to 7018,  I'd balance the extra cost  with time in service.  Maybe just build it back up with the 7018
GMT+8, 2025-12-27 20:39 , Processed in 0.107458 second(s), 18 queries .
