Millermatic 200 REDO
发表于 2021-8-31 23:15:26 | 显示全部楼层 |阅读模式
This is my resto (if anyone cares).Fixing and painting the wrapper with PPGAdding cut and rewelded tank rackTA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Finished product (So Far)TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Nicely done!  I trust it looks as good as it welds now.PapaLincoln Idealarc 250 (circa 1962)Lincoln Weldpak 155 w/Mig KitLincoln Squarewave TIG 175
Reply:OF COURSE WE CARE!!! Very nicely done and you weren't kidding when you said it wasn't pretty when you got it.  A unit anyone would be proud to own now. All you need now is a real tank. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I take it you don't plan on ever using that Spoolmatic 1 (at least much) seeing as you modified the tank rack to a single unit.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Sexy time! Looks great.
Reply:Originally Posted by duaneb55I take it you don't plan on ever using that Spoolmatic 1 (at least much) seeing as you modified the tank rack to a single unit.
Reply:Oh damn!!!  Lookin stellar!Sorry to bump the old thread, but man that really does look sharp.JoeMiller 140 Autoset (2010)Miller Syncrowave 250 (1996)
Reply:Thanks.  It's a great machine.  The only problem I had with it was dirty unsquared contact points on the old style CR1.  I hit them with some emery paper and squared em up.  Zero other problems.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Nice job! The old Migmatics seem better built than the new mig welders, although they are still as gutsy! Thanks for sharing the project with us, often shows old machines can still kick it!!
Reply:Originally Posted by Drf255Thanks to all.  I thought about keeping the dual rack for that purpose, but the footprint of the machine was just too big to fit in my garage.  Those wheels hanging off the back really took up a ton of space.For the spool, I have a large (?330) 5' tall Argon tank on my Synchrowave.  I had a separate regulator already that I dedicated to the spool gun.  For the amount of welding I do, it wouldn't pay to buy another full size argon tank.   So when I use the spool, I just hook the reg up to the synchro tank.The baby tank was just filled for $24 with C25 for my little guy, so it made no sense not to use it up before trading up to a real one.  And yes, it welds as great as it looks.  I only wish I could get a replacement front panel.
Reply:It's not, I called Miller.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Nice job man ! it really pays to fix up those old machines i 'll bet if you put that on CL you would have people fighting over it . i restored a 1989 MM35 that was almost as ruff as yours and used it for about 6 yrs. and sold it for what i bought it for  and had many calls on it . i had 2 guys call 2or 3 times to make sure the guy i sold it to came and picked it up . so it definitely pays to restore em ! again nice job ,and YES we do care this is why we all spend so much time on here ! lol.. chris
Reply:The older machines are built much better.Matter of fact they did not have those 3 year warranty stickers.They were built to last a lifetime.AWS certified welding inspectorAWS certified welder
Reply:Hey, if you used off-the-shelf rattle cans what exact paint did you use? The old Zynolyte had a blue that almost perfectly matches Miller blue of that era, but I don't know what to get today. Not a painter, don't own a spray gun setup ..
Reply:I see this is an old thread.  Now that you've had time to weld with it, how do you like it?  Have you researched the serial number to find out when it was made?  Do you have any pictures of the wire drive system?Lincoln Powermig 255Hypertherm Powermax 45Thermal Arc 161SOxweld 24R OA TorchStill Looking for an Old Round Top Idealarc 250
Reply:I believe it's an '83.  It is a beast. The fan on demand almost never comes on.  The drive system is a 2 roller.  I put a Bernard Q300 gun on it.  Hasn't missed a beat since I cleaned up the CR1.  The paint was custom mixed PPG single stage urethane.  I brought the side cover to the paint shop with me.  They have a new lower priced line.  The paint, reducer and hardener were $50 and I have extra.  Best of all was the price.  I got it with a working Spoolmatic 1 for $299.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Nice machine. If you ever want to use a larger cylinder those work just fine run with a long hose on a quick disconnect from a cylinder cart. I don't really like pushing a machine with a large cylinder on it (old age, bad back), so I don't.
Reply:I think those dual cylinder racks are too wide. It makes the rear of the machine too wide to fit through small areas.
Reply:I rather prefer mine.  I like having both tanks right on the machine.  I guess it just boils down to a matter of personal preference and shop layout.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Nice job on it!You mentioned it is a 1983 and it has fan on demand. I wish my 2003 Shopmaster had fan on demand. As I get older, "shop noises" tend to annoy me some."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
GMT+8, 2025-12-27 20:30 , Processed in 0.146242 second(s), 18 queries .
