Tractor Ballast
发表于 2021-8-31 23:15:20 | 显示全部楼层 |阅读模式
Hey;Wanted to give the snowblower rig some good footing. Figured best way was to make a ballast box on arms that extend better part of 2 Feet to the rear. Compound the weight that way. Used my brain and Weldanpower CV 225 at 125, 1/8" - 6013 . Got to love those old Cast Iron Briggs Industrial mills. Now BIG improvement in traction with 250 in the hold. No slip .All the best Attached Images
Reply:Does it need “Wheelie Bars” now?
Reply:Nice weight box.My second favorite is RV antifreeze filled tires
Reply:Nice job!! The one weak spot I see is those skinny little axles.                                              MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Better get busy, looks like you have a lot of GREEN SNOW to deal with
Reply:Looks good!  Becareful dont BOLT it to the ground too good!! something needs to slip or you will be using your welder for something other then a weight box
Reply:Hard to beat tire chains!  Really helps on hard packed snow and ice.
Reply:6013? ?is the angles galv?
GMT+8, 2025-12-27 22:21 , Processed in 0.076019 second(s), 18 queries .
