Stick Welding with my Syncrowave 250?
发表于 2021-8-31 23:15:15 | 显示全部楼层 |阅读模式
So I have just started getting back into the swing of Stick welding. What are the preferred settings for stick welding 3/16 angle?  Will painted angle disrupt or cause a bad bead? I have noticed that my syncrowave will only initiate an ark while stick welding if I press the foot pedal. Is this normal?Sent from my iPhone using Tapatalk
Reply:You need to switch the switch on the panel for remote arc start to off. Also clean the base material before you weld it up.1973 Lincoln SA 200, Already replaced shunt coils, Idle board (SOLD)1984 Miller Dialarc 250HF, Miller water cooler, 250 AMP water cooled torch, you know the worx.
Reply:What Tuscany said. Also, if you want to avoid cleaning the steel real well, use 6010 or 6011, and it'll eat through the paint/grease/dirt, though you won't get as pretty a weld as you would if you cleaned to shiny steel and used 7018.
GMT+8, 2025-12-27 20:29 , Processed in 0.237131 second(s), 18 queries .
