Sa-200 should I ?
发表于 2021-8-31 23:15:14 | 显示全部楼层 |阅读模式
I have a chance to buy a sa-200 k-6090 for $750 no doors hoods dented pretty good been siting out side all winter, should I chance it ?
Reply:With that code if I remember correctly should be a 68 I think. It will be a round barrel gen with a continental F163. The face plate should be one piece stamped steel with the lead terminals on the front of the machine. Its copper so yes it is worth the 750 just in parts. Does it have a rain cap on the exhaust? Look to see if it has the hand crank and try to see if you can spin it over by hand but be careful. If there is no rain cap it could be a simple stuck valve or it could be a stuck piston. For 750 i think i would get it even if the motor is locked.
Reply:150532 is the serial #
Reply:Are you sure on the SN and Code#?  A 150532 SN would make it of '45 vintage which is pre-K6090 - I think.Last edited by duaneb55; 04-10-2014 at 10:25 AM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Yeah I figure that's not right that's what it says for a serial number but when I called lincoln they told me that was the code where is the serial number ?
Reply:The "A" number is the SN.  Could it be you read a 7 as 1?  That would make sense and line up with a K6090 if I'm not mistaken.You can check this area of the main housing for a code#.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I'll check when I get to the shop thanks agian
Reply:No luck finding it on the housing it's a canadian version and what see on here it's a bit of a challenge to figure out the year
Reply:I dunno, I would make sure it welds before purchasing. that is hex-gen, so has to be 70s or newer.I bought an 88, and after 4 months just finished it. it looked about like yours does. test shunt-coils before paying that much, or else you will be tearing the whole thing down. . . .the rest of what could be wrong with it is pretty easybosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:It does weld, and the auto idler works to my surprise, I didn't think $750 was bad I know red faces are better, but the only red face I've seen for sale up here was $6000 and it was pretty weather warn thanks for the info
Reply:If it runs and welds, i would take it! you couldn't pay twice that for a crappy welder, not to mention one of the best made. but hey, i enjoy stuff that requires a little checkup now and then.bosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
GMT+8, 2025-12-27 20:29 , Processed in 0.154034 second(s), 18 queries .
