Lincoln ac/dc 300
发表于 2021-8-31 23:15:10 | 显示全部楼层 |阅读模式
I found a used lincoln ac/dc ideal arc for $500. I think it has ability for HF tig welding. Is it worth buying? Can it be run on a 50amp 220v? I am trying to get a tig setup on a budget. Any suggestions? Thanks for any input.
Reply:Originally Posted by CzoppI found a used lincoln ac/dc ideal arc for $500. I think it has ability for HF tig welding. Is it worth buying? Can it be run on a 50amp 220v? I am trying to get a tig setup on a budget. Any suggestions? Thanks for any input.
Reply:Originally Posted by Stick-manMake sure it's a single phase machine. It depends on how much output you want. I have run my Shopmaster on a 50a outlet and it was fine. I was running a wire feeder with .035" hard wire. It was not close to max output and it was fine.
GMT+8, 2025-12-27 20:51 , Processed in 0.121858 second(s), 18 queries .
