Practicing my TIG
发表于 2021-8-31 23:15:03 | 显示全部楼层 |阅读模式
My son's woodshop teacher is having them build a soapbox derby car. My son volunteered my services to weld the front axles up. This is the only part of the project I am involved in. They are forming the car out of wood and handlaying fiberglass over it. Our town has a derby once a year.Anyways, this picture is of my joint that I did autogeneously in the flat position. This weld will be in the vertical position on the car. The welds in the horizontal position I have welded with filler. This vertical weld was just to close up the end of the tube. It was actually unneccessary to do.So what I was shooting for was a consistent bead size, wetting out the top of the joint evenly so as to not leave a series of copes that makes it look jagged and for general appearance. I am not good enough yet to make my beads look perfectly stacked. My consistency with TIG is hard for me due to my inability to hold small objects with any steadiness. I have a hard time holding a pencil or a pen. My wife buys that really fat pens for me to use. Kinda makes me feel like the short bus kid that uses the extra fat crayolas. lolFeel free to comment, good or bad, and add suggestions.I was using my Lincoln PrecisionTig 275, DC-, no pulse, footpedal, 200amps max, and 3/32 E3 tungsten from AirGas. Never used it before, but I do like how it holds a point!!!! Way better than my thoriated.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:looks pretty solid to me, IMO it could have a little more convex to it but it might just be the lighting. what is the thickness of the 2 pieces, 1/4"?mike
Reply:Good from here!That will last forever!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Looks great on my phone! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Maybe one of those TIG pens would help add a little thickness to your filler rod making it easier to hold steady. Your weld looks great. Ought to last forever. Sent from my DROID RAZR using Tapatalk 2Hobart Stick mate LX AC/DCHarris O/A outfit
Reply:maybe I need to switch to far pens too, cause I cant do anything that pretty!miller syncrowave 250hobart handler 140home made 400 amp engine driven in progress...
Reply:That's not your first rodeo Looks great Not gonna come apart .V
Reply:Weld looks great to me.  As for the holding small things, have you thought about modifying your TIG torch so that it's easier for you to hold?  I think a bit of Sugru (https://sugru.com/) (I have no relation to the company, nor interest in their profit margin...but I've used this stuff and it's a good product) applied to it to make it thicker and comfortable for you and you'd be good to go.--Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
GMT+8, 2025-12-27 20:40 , Processed in 0.088795 second(s), 18 queries .
