Crazy
发表于 2021-8-31 23:15:01 | 显示全部楼层 |阅读模式
Silly ? But is fluxcore technicaly short circuit
Reply:No.  When it's dialed in right and running good it's real close to a true axial spray.Last edited by HT2-4956; 04-11-2014 at 11:19 PM.
Reply:So how can it be all position
Reply:FC can be run in short circuit or spray. Depends a lot on what you have as far as a machine. No way you'll go into spray on small machines, you simply don't have the power to do so. However with bigger machines you can run FC wire up in spray and it's often done with large wire to lay down lots of material.FC in spray can be a real PITA out of position..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I have a thermal arc fabricator 252i it's a 300 amp unit
Reply:You can do either with that machine.  It's got enough power to spray mid sized wire..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:True code flux core is spray transfer, the slag is what makes it an all position operationVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Are u talking no gas fluxcore  I am using nr 211 mp
Reply:Originally Posted by DSWFC can be run in short circuit or spray. Depends a lot on what you have as far as a machine. No way you'll go into spray on small machines, you simply don't have the power to do so. However with bigger machines you can run FC wire up in spray and it's often done with large wire to lay down lots of material.FC in spray can be a real PITA out of position.
Reply:What about gas less
Reply:Have u used lincoln nr211mp
Reply:Originally Posted by FlyingJSilly ? But is fluxcore technicaly short circuit
Reply:So why are there all these entry level flux core machines ?   I'm just curious as the stuff you see at menards ( Campbell) and the entry level migs at home depot and what not.   Never had a chance to use them personally but just curious as to their popularity .  I assume price point and fact that home user doesn't need gas ?Miller 350PMiller 30AHobart trekHTP Invertig 221
Reply:Originally Posted by padronanniversarySo why are there all these entry level flux core machines ?
Reply:Lol. Classic !Miller 350PMiller 30AHobart trekHTP Invertig 221
Reply:Originally Posted by walkerweldThey are for building trailers out of bed frame stock
Reply:So  I have ran this stuff on some projects but have a ? For u guys can you give me some idea of settings for 1/4 inch
Reply:Lincoln nr 211 mp tried Lincoln's recommendations but they look way off
Reply:Originally Posted by FlyingJLincoln nr 211 mp tried Lincoln's recommendations but they look way off
Reply:Tried 23 v 280 ipm and had porosity so tried 17 and 190 that helped bt didn't seem like spray
Reply:Originally Posted by padronanniversarySo why are there all these entry level flux core machines ?   I'm just curious as the stuff you see at menards ( Campbell) and the entry level migs at home depot and what not.   Never had a chance to use them personally but just curious as to their popularity .  I assume price point and fact that home user doesn't need gas ?
GMT+8, 2025-12-27 20:49 , Processed in 0.190704 second(s), 18 queries .
