Finishing Stainless Steel sink...Help?
发表于 2021-8-31 23:15:01 | 显示全部楼层 |阅读模式
Hey guys, i have a job this friday at an retirement home that has a stainless sink/counter. The crack is about 12'' long. My question is: after welding what is the best/fastest method to sand the weld down and finish the surface to the "scotchbrite" finish??? Should I bring my compressor and air tools? Thanks for all the help in advance. -Brandon-
Reply:Looking forward to the responses, as I have a friend who owns a restaurant / bar that needs some work done on one of his SS sinks.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:take u a aluminum or copper bar to back or surround the repair area. Keep you a good stainless wire brush handy, if the crack is in a hard to access area thats about all you will have to take the color out of the ss. Since it sounds like you have no specialty tools for refinishing, a cut off wheel may be your best friend for grinding the weld down, some roloc wheels, some drum style sanding wheels, some scotch brite both for you grinder and hand. Most of the time if it is in a kitchen environment they are not picky about what it looks like. Good luck!
Reply:I'm just going to use my 90* air grinder. I have all the sanding pads from 80g to a fine buffing pad. Ill snap a couple of pics of the final result. thanks
Reply:Use a backer bar like kkustomz said or it will look like a taco when you're done. You have to add filler if you are going to grind down the weld. Sent from my iPhone using TapatalkWe offer correct, cheap and fast. Pick two.Weldanpower G800XMT 304Syncrowave 250Millermatic 135Maxstar 91Heliwelder 4A/DDR 224/HPA/BHFT Plasma
Reply:could you not grind down the weld with a flap disk, followed by finer sanding the surface to match the rest of it?
GMT+8, 2025-12-27 20:51 , Processed in 0.100047 second(s), 18 queries .
