Keeping Track of Duty Cycle
发表于 2021-8-31 23:14:56 | 显示全部楼层 |阅读模式
I have a small 110v Craftsman Wirefeed. I think it has maybe a 20% duty cycle at max output. I understand how duty cycle works but i am wondering how i can make sure i do not exceed the duty cycle and damage the machine.
Reply:I used to have a little craftsman mig and I hit the duty cycle/ outo shut off dozens of times....I doubt you'll damage it.Farmer2Hobart Champion EliteMiller S-32p 12Lincoln sp175tLincoln 225 ac tombstoneHarris oxy/aceteleneMakita grinders/chopsawHypertherm Powermax 45
Reply:Originally Posted by farmer2I used to have a little craftsman mig and I hit the duty cycle/ outo shut off dozens of times....I doubt you'll damage it.Farmer2
Reply:They usually either shut off or a light turns on. RTFM (read the manual)Welding/Fab Pics: www.UtahWeld.com
Reply:some machines kick a light on and become (cold) aka wont  strike a arc until cooldown is reached, others will just flip the breaker switch
Reply:Who cares. If it goes kapoof and your serious you'll get a good machine. A craftsman welder is like a step below eastwood and a halfstep in front of harbor freight.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by 17jamatoWill it shut itself off?
Reply:It should shut itself off.No power, but fan will still run.Did on my weld-pack HD....FWIW~JohnJust a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:I know I've exceeded the duty cycle on my old Idealarc many times, but it keeps on going.  I just love old machines. "Hey I didn't come to look and learn, I came to turn and burn.... If I can't light up, I'm gonna light out!"-JodyIdealarc 250 "Fatman"MM 252MM 211 "Little boy" Victor Torches
Reply:Run it until it blows and upgrade ! It's only 120, burn it up and get into a 220 volt machine.
Reply:kitchen timerMikeConstans Fides et IntegritasLincoln Weldanpower 150 ACAirco Aircomatic MIGet CAV II w/ spoolgunMillermatic 30a wirefeeder
Reply:A lot of machines dont shut off. My on a hot day lincoln mig will just keep running until it heats up so much the weld loses most of its heat and just sits on top.Another thing to consider is ambient temperatures. If its at or around 40f its going to be difficult to get the insides of the machine hot at all.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:Originally Posted by mad welder 4A lot of machines dont shut off. My on a hot day lincoln mig will just keep running until it heats up so much the weld loses most of its heat and just sits on top.Another thing to consider is ambient temperatures. If its at or around 40f its going to be difficult to get the insides of the machine hot at all.
Reply:Every machine I've hit the auto shut off on the welds have started to look like crap and not penetrated well before the thermal shutdown.  When that happens its usually beer thirty to let the machine cool off for a bit.Miller 211 MIGThermal ARC 186 TIGHypertherm Powermax 30 Plasma
GMT+8, 2025-12-27 20:50 , Processed in 0.114195 second(s), 18 queries .
