Bad Gas.......
发表于 2021-8-31 23:14:51 | 显示全部楼层 |阅读模式
NO not farts.......LOL  I hooked up a new bottle of gas yesterday and started to weld some parts and the weld had black flakes floating up?I changed bottles and it went away......It's the same gas company I have been using for years and never had a problem........With the price of this bottle (92.00) it shouldn't have happen.......Blueshield -1   Argon/Helium  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Well, did you roll it first to mix the gases? (Sorry, I couldn't resist!)
Reply:Bad gas.Take it back to the supplier, along with your coupon.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:I would definately take it back and tell them someone F'ed upVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Looks good from my house! Lol
Reply:Definitely not impossible.I had it happen twice in a row as an entire batch from Airgas (the entire fill line or main tank they were filling from) had trace moisture in it that was dissociating into 02 and H2 in the arc plasma.My welds on Alu with bad gas looked just like yours. Little to no cleaning action, black oxides floating around,etc.Took the sales ticket back and swapped both times. Laurel gas guys were pretty good about the whole fiasco lol.I've noticed it's worse with the smaller tanks that small shops or hobbyists would use. Folks sometimes run them down to 0, leave valve open and air gets in with ambient temperature changes. It's on the filler to purge the tank at that point otherwise dumping new gas in cruds up the entire fill.And your right it shouldn't happen especially to the folks that depend on gas for a livelihood, but anyone who would be on the ball, all the time, probably won't be working as the bottle filler.HTP Invertig 221-DV -- get's dragged everywhere.Syncro 200 -- "The Boat Anchor" at the lab.Lincoln 125 MIG
GMT+8, 2025-12-27 22:12 , Processed in 0.154023 second(s), 18 queries .
