learning tig
发表于 2021-8-31 23:14:49 | 显示全部楼层 |阅读模式
i have recently picked up a tig. my first major project is a sissybar for a bike(motorcycle) im building. ive got some undercut spots on the weld. i welded 2 1/2" pieces of round stock together to get some ornamentation to the piece. will undercutting weaken the weld? will making another pass fix the issue or is it scrap?
Reply:Originally Posted by sickboi55will undercutting weaken the weld?
Reply:A sissybar goes behind the seat so the passenger has something to lean back on while holding on for dear life...Not something for a novice to be making.If you can fill in the undercut then it should be OK but having no undercut the first time is the goal here......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:zap i just noticed your sig says in the end it looses...should be loses lol
Reply:Originally Posted by cboyzap i just noticed your sig says in the end it looses...should be loses lol
GMT+8, 2025-12-27 22:14 , Processed in 0.108287 second(s), 18 queries .
