When you have to weld aluminum outside is there a way to do it without using gas
Reply:Nope their isn't
Reply:Yes, aluminum stick welding rods on DC+Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:There are stick welding rods made for aluminum which would be the only way to weld aluminum without gas that I am aware of.Of course, those stick aluminum rods are a unique experience unto themselves. Some love em - some hate em. Either way, the material thickness that they are usable on is a limiting a factor. Welding Web poster "Rick V" did some research with aluminum stick rods a couple years back contained in about 2 to 3 different threads that makes for some good reading if you do some searching.
Reply:The 3/32 are really too soft to stick weld with, get the 1/8th if you have to use them. Definitely not an option for thin aluminum. Also consider zinc rod with propane torch Sent from my SCH-I545 using TapatalkTiger Sales: AHP Distributor www.tigersalesco.comAHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma. For Sale: Cobra Mig 250 w/ Push-pull gun. Lincoln Wirematic 250
Reply:Originally Posted by FlyingJWhen you have to weld aluminum outside is there a way to do it without using gas
Reply:Originally Posted by FlyingJWhen you have to weld aluminum outside is there a way to do it without using gas |
