Looking through the gap
发表于 2021-8-31 23:14:44 | 显示全部楼层 |阅读模式
Do many of you guys use the looking through the gap technique on your tig roots ?  I think I want to practice this method for tig rooting stainless and carbon.I see nothing but benefits from this.  You watch your root go in.  No more stopping and looking through the gap to be sure you are getting it in there,  you see it while you weld.    For the stainless I could just tape a clear lens over the root where im looking through.Journeyman / Red Seal Welder (What a useless test)Miller CST 280Miller XMT 350Miller 12vs XtremeEvolution Evo 28 mag drillEvolution 380 Dry Cut saw
Reply:This kid does it. Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:UH.Don't try that at home. That nut is a robot.I can do it with a brazing rod ! Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:A guys is gonna need some pretty long arms for this to work.Miller xmt304,  Miller S22 p12, Miier Maxstar SD, Miller 252 w 30A, Miller super32p12, Lincoln Ranger 9, Thermal Arc 181I with spoolgun, Hypertherm 10000 ,Smith torches. Esab 161lts miniarc.
GMT+8, 2025-12-27 22:25 , Processed in 0.111514 second(s), 18 queries .
