Cranes
发表于 2021-8-31 23:14:42 | 显示全部楼层 |阅读模式
How to weld the parts of cranes?? What are the equipments needed for it??
Reply:Where ?Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Absolute necessity when working on cranes.  I prefer to use this over welders as it's a pain in the arse to haul a welder to the top of a crane.
Reply:what sort, and size, of crane are we talking?
Reply:Originally Posted by ttokswhat sort, and size, of crane are we talking?
Reply:I couldn't get a ground on this one...maybe I need a new clamp? Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by rosebyrne What are the equipments needed for it??
Reply:Originally Posted by rosebyrneHow to weld the parts of cranes?? What are the equipments needed for it??
Reply:No welding necessary. Attached Images
Reply:Them thar tastes like chickenz !Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:A company I worked for had a lattice-boom 'Manitowac' (?) crane (a year younger than me, 1948). It came with manuals for making/repairing about everything about it. There were very specific instructions on replacing the 'lattices' (webbing) on the boom. Cut no closer than 1" away from frame, grind & cool, etc. till removed, make a 'perfect' fit with replacement web, weld in quadrants plus switch ends of new web when welding in new web, etc. Very, very detailed manual. It had a Caterpillar engine at least 6 ft long with a hand cranked pony motor starter with a 2 speed tranny. If you started it, you did not shut it off till quitting time, whether it was used or not. Redline speed was 1800 rpm.
Reply:What everyone is telling you, Rosebyrne, is that YOU do not weld on cranes. You call a professional welder to do the job, and you make (insert your own expletive here) well sure that he is certified, licensed, bonded, and has been trained on your type of crane.  This is not a 'Hey, I've done a little welding, I can fix that boom right up' type of job. If you or your employer thinks it is, then you both need to be required to stand directly under the next 50 loads it moves.Cranes are nothing to mess with, even your little garage engine puller type. Crane failure will, if you are lucky, only cost you a few dollars in broken parts, and broken bones if you are in the way.With bad luck, or incompetence, you kill people, and cause catastrophic damage to property that does not belong to you.The fact that you, in your first post here, ask about such a thing, is why you got the responses you did.MillerMatic 252Miller Xtreme 625Miller Digital Elite
Reply:Originally Posted by DaeyelWhat everyone is telling you, Rosebyrne, is that YOU do not weld on cranes. You call a professional welder to do the job, and you make (insert your own expletive here) well sure that he is certified, licensed, bonded, and has been trained on your type of crane.  This is not a 'Hey, I've done a little welding, I can fix that boom right up' type of job. If you or your employer thinks it is, then you both need to be required to stand directly under the next 50 loads it moves.Cranes are nothing to mess with, even your little garage engine puller type. Crane failure will, if you are lucky, only cost you a few dollars in broken parts, and broken bones if you are in the way.With bad luck, or incompetence, you kill people, and cause catastrophic damage to property that does not belong to you.The fact that you, in your first post here, ask about such a thing, is why you got the responses you did.
Reply:whats with all the trolls thinking they're funny lately?Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Story is don't touch it unless you are qualified and  have enough insurance to cover what could happen. J. R. Bauer
Reply:You guy's should be nice to the poor guy, LOL.I'm sure everyone of you asked a not so good question some time in your life, I know I did.I did get a good laugh from some of your postings.Be nice!
Reply:No I am saying cover your But been there done that. J. R. Bauer
Reply:rosebyrneFirst consideration: is your shop O/R Sanitary.  If so, you have a choice of procedures - they are:Ornitho/desis: fusion of two parts into one, or Ornitho/pexy: to fix or secure stabilization.If your question is Fe based: is your problem; top or bottom, an inny or an outy, on the farm, or requires weld certifications?Opus
Reply:Ok boy's I would not make not make a good zit on most of your boy's a$$y but been there done that  crazy be ready to bull **** ready to bull **** your way to be ready to bull **** your way out of your way out of it. J. R. Bauer
Reply:Can't you guys tell this thread is a joke?? Ignore it!!Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:AKweldshopThis is High Theatre - please stay 'in character'.Opus
Reply:It's really not that difficult.  First you anchor the crane with something heavy, so that it's stable, like this:Then, you lower the boom so that it readily accessible, like this:Then, break out a 110v mig and get busy.
Reply:before you do any welding you need to have access to the broken part. use this. Attached Imagesi.u.o.e. # 15queens, ny and sunny flaI spoke with Barry Soetoro on this matter. He has referred me to an expert/and family menber/ in the art of craniation to review and recommend a solution to your problem.You can adress him as C.C. ( Crane Czar)Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Inexperienced welder, or inexperienced crane operator. Bad things always seem to happen when you're not qualified for the task. I was the rigging foreman who got the privilege to work with the divers to pick this 18-ton hydraulic crane out of about 120-feet of water. When it happened I was on a different radio channel, but was told latter the last thing the operator said on the radio was, "hey guys I think I'm getting light". Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I did not do that was not there can't Blame me. J. R. Bauer
Reply:Originally Posted by CEPYeah in my time I've worked with a wide variety of sizes of cranes.
Reply:Originally Posted by JTMcCThat's a very big can in the picture.
Reply:Originally Posted by BurpeeI spoke with Barry Soetoro on this matter. He has referred me to an expert/and family menber/ in the art of craniation to review and recommend a solution to your problem.You can adress him as C.C. ( Crane Czar)
Reply:I've always had a soft spot in my Black Little Heart for big can's.Be they in Pilebutt land  or belonging to a female : )The former have provided much income for the (significant) latter in my world : ).That's a big yeller APE in the picture, John White who started APE is a good (and funny) guy, a Make it in America guy. His equipment is sound. J
Reply:I made way more money with concrete. John White and I don't get along to well, he lied to me in the early 1980s when he was with ICE. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Concrete pile is the work of the devil.Pile should be round, big bore, heavy wall, carbon steel, welded, pipe.Period. Tho I have made a few welds on concrete pile, I in no way endorse the evil that they hold.Those may fly in Seattle area, or back east, but not in the beautifull southwest : )J
Reply:Only reason concrete pile are used, is they're cheap! Next time you're over at the Port of LA, look under all those container ship docks, all concrete pile. Driving concrete pile separate the men from the boys. Just like welding pipe does! Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by CEP. When it happened I was on a different radio channel, but was told latter the last thing the operator said on the radio was, "hey guys I think I'm getting light".
Reply:Originally Posted by CEPOnly reason concrete pile are used, is they're cheap! Next time you're over at the Port of LA, look under all those container ship docks, all concrete pile. Driving concrete pile separate the men from the boys. Just like welding pipe does!
Reply:Originally Posted by JTMcCThe boom on the American would rotate about 20' after the house was stopped. Had to figure in the large amount of slack in that boom : )
Reply:Originally Posted by CEPWOW!So when the rigger phoned in the single "easy on the swing", he really had to add in some windage!
Reply:Originally Posted by JTMcCRight, it would swing past, then settle back somewhere in the middle.They bid it for a 4100 on a ringer, so using the old American saved several hundred thousand.J
Reply:Man cant a guy just ask a question. Maybe he is just curious. Some of you post are funny as heck though.Fireman BillHH 210 MVPMM 211 Spoolmate 100Lotas LTP5000D PlasmaOxy/Accet (Victor)Wards AC/DC buzz box30 ton old hyd pressA few brand name toolsA bunch of cheap toolsA wife to worry me and4 dogs to supervise me
Reply:@ CEP - yeah bro.  The sea separates the men from the boys.  "No cure, no pay."  Rip'd many wild times afloat.  Heavy work. 20hr days.  None better."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:The operator of the track hoe is nuts Attached Images1982 miller blue star 2E ac/dcHarbor freight flux core posVictor oa
Reply:Yes but he got her done. J. R. Bauer
Reply:Now this is a crane! Wonder what that puppy is rated for? Biggest I ever worked with was a 1,000-tons. I guess they're going to try and pick that sunken ferry in South Korea. I worked with a stiff leg crane for about a year, now the swing in these really sucks!  Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I normally work with 40-250 ton cranes and just the thought of something that big is interesting to me. I'd love to be on a job like that.Sent from my iPhone using Tapatalk
Reply:That DB General I posted a picture of earlier can pick a 1,000-tons over the working end, 750-tons full revolving. It sets on a 100-feet wide x 400-feet long barge. Surprising how small the draw works, (winches) are. This derrick here, when you walk in the engine room you would gasp at the size of the draw works! It has 3,000-ton draw works in it, but only rated at 165-tons. It runs 2-inch wire rope. The operators tell me it will pull the wire rope into with out any problem.  Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by CEPThat DB General I posted a picture of earlier can pick a 1,000-tons over the working end, 750-tons full revolving. It sets on a 100-feet wide x 400-feet long barge. Surprising how small the draw works, (winches) are. This derrick here, when you walk in the engine room you would gasp at the size of the draw works! It has 3,000-ton draw works in it, but only rated at 165-tons. It runs 2-inch wire rope. The operators tell me it will pull the wire rope into with out any problem.
GMT+8, 2025-12-27 22:13 , Processed in 0.108367 second(s), 18 queries .
