Power max 30 air water everywhere
发表于 2021-8-31 16:58:38 | 显示全部楼层 |阅读模式
I just purchased a used powermax 30 air. The guy who sold it to me demoed it for quite a while. As soon as he left it kept throwing the consumable error code and changing to new consumables did not help. Tech support had me remove the cover and there was standing water in the seperator somewhere around an inch. I removed the seperator and topped it up with water to test the drain. It would drip about every 5 seconds. The torch head also had a fair amount of water in it. I've order a new seperator bowl as I snapped that little drain off the end when trying to remove the drain line. Hypertherm recommended I open the machine and give it time to dry out. We were using it in an extremely humid basement. My question is was it just a bad bowl drain or can the 30air not be used in a very humid environment? Would it be useful to add an additional dryer? Thanks much
Reply:Nature of the beast. The plasma's with built in compressors make their own moisture. Hobart, Lincoln, Thermal Dynamics and Hypertherm.  The portability is nice but just plan on burning up a bunch of consumables.Thermal Arc 320SP ( Lorch )Cobra PythonsThermal Arc 300 AC/DC  ( Sanrex )ESAB 301i AC/DC  ( Lorch )Thermal Arc 161STL  ( WTL )Thermal Arc 190S  ( Sanrex )Cut Master 82, 42. Cut45 ( WTL )Victor Gas Apps.Boxes and boxes of welding crap.
Reply:With the auto drain properly repaired the Powermax30 air will work fine in a humid environment. It is normal for an occasional puddle of water under the unit as there is an auto drain on the coalescing filter that drains water that the internal water separator does its job.  Jim Colt
Reply:Replaced the seperator and seems to be working fine. Thanks
GMT+8, 2025-12-18 16:17 , Processed in 0.099282 second(s), 18 queries .
