Doin' it right?
发表于 2021-8-31 23:14:24 | 显示全部楼层 |阅读模式
I take it im doing something right...  sorry its upside down...Sent from my SAMSUNG-SGH-I337 using Tapatalk
Reply:Um, you need to be a lot steadier with the torch. Cuts look very jagged.(somebody was going to say that)
Reply:7024???Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Yeah, me an the torch aren't friends at the moment (have only known how to use it since monday).Yes its 7014 @ 140A.
Reply:Why does it look like there is a crack down the center of the weld?You should clean it and post another pic.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by MinnesotaDaveWhy does it look like there is a crack down the center of the weld?You should clean it and post another pic.
Reply:This was a Practice piece. The instructor handed me 4 rods of 7024 and said run it and see what happens... (was using 7018 prior).That picture was like bead #2 out of 6 total.The weld that you're seeing is stacked, but the reason it looks like its cracked is the stupid lighting in the shop. (SUCKS for trying to do any critical viewing)
Reply:Yep, Slag peeling up, in my opinion, means, your arc length, travel speed, and amperage are set right....7018 will do it, if your "perfect"....7024 and 7014 sometimes look like crap while your welding, but you flip up your helmet, it looks real good.But sometimes the slag curls up, but the weld is not the best....Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Im not sure why we started on 7018. Maybe to force us to watch the puddle. The 7024 doesnt really have a discernable puddle.Sent from my SAMSUNG-SGH-I337 using Tapatalk
GMT+8, 2025-12-27 22:26 , Processed in 0.125515 second(s), 18 queries .
