Floor grate project
发表于 2021-8-31 23:14:16 | 显示全部楼层 |阅读模式
I'm in the process of making a cover for a water holding tank. The tank is going to be set into a concrete floor and it's about 6' dia. I decided to go with a 10 sided polygon shape. That way it saves some material and I wouldn't have to  have someone else cut out half moons. I used 10"x3/16" plate with a 2"x3/16" lip. I'll be using 3"x1.5" C-channel for the main cross supports. The tank will have a pickup pipe running into it so the customer wanted it built in 2 pieces so the cover can be taken off to clean the tank out now and then.Chicks Dig Body DamageMiller Dynasty 200dxHobart Handler 187Lincoln AC 225
Reply:is it going to have a hatch or just be a lift out unit?There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:looks like a great start!
Reply:It's going to be lift out. Should be ok for 2 guys.Chicks Dig Body DamageMiller Dynasty 200dxHobart Handler 187Lincoln AC 225
Reply:Just out of curiosity is that a modern day cistern?Shake and Bake
Reply:rain water storage? How deep is that 6' wide hole?Last edited by jdchmiel; 11-15-2012 at 10:19 AM.miller syncrowave 250hobart handler 140home made 400 amp engine driven in progress...
Reply:Solid built by far.  Keep us posted with the final outcome.  ________________________________________www.sawblade.com
Reply:The first thing that came to mind when I saw this hole was, It puts the lotion on its skin or else it gets the hose again.    [ame]http://www.youtube.com/watch?v=7rgSnm2-2ps[/ame]Last edited by Cartman; 11-15-2012 at 10:11 PM.
Reply:The hole is used for water that is recirculated for cutting tile. I think it's about 6' deep, supposed to hold 1000 gallons.Chicks Dig Body DamageMiller Dynasty 200dxHobart Handler 187Lincoln AC 225
Reply:Originally Posted by CartmanThe first thing that came to mind when I saw this hole was, It puts the lotion on its skin or else it gets the hose again.
Reply:Well I've finished this project and it turned out great. Hope to deliver it tomorrow and hope the check signer is there. My phone broke so I haven't been able to take or post any pics but hopefully I'll get a few before I take it in tomorrow mornin.Chicks Dig Body DamageMiller Dynasty 200dxHobart Handler 187Lincoln AC 225
Reply:I thought it would turn out Grate.... Budump CHHHH! I'm here all night people.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:I ended up getting a few picks with someone else's phone After I loaded it up. Lucky for me the two pieces fit right in the hole nice and tight and the shop manager there was very empressed with them.I made up some handles real quick out of some flat and round bar I had. They make it a lot easier to lift out the grates.Chicks Dig Body DamageMiller Dynasty 200dxHobart Handler 187Lincoln AC 225
GMT+8, 2025-12-27 22:25 , Processed in 1.389570 second(s), 18 queries .
