I'm working on the base for a large nameplate and found two large pieces I used as legs on an old welding table.......... 36" long, 1/4" thick.......It took a couple hours to weld out both sides......I chopped all the video down to about 8 minutes.......Something to watch during that first cup of coffee I guess......Here it is.......Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:That's gonna be one heavy nameplate! Nice stick welding. I don't think I've seen much stick welding before. Does it make the shop all smokey? Why not use your mig since it isn't a trailer it just has to look nice? Nice video fexMiller diversion 165Miller mig 211Hypertherm pm 30Milwaukee 6230 14 inch chop sawMd 45 mag drill (RIP; fell on its head)New MD 45! Thanks to the esposa!Finally got an O/A setup
Reply:Thanks Eliot....My MIG is just a 110v machine and would just cold lap the tube if I used it.... in fact... these were the legs to a welding table that I built with that little MIG.... and I was able to break it apart with a 4lb sledge when I built a new one......It does make the shop smokey, but I keep the fan on full blast to blow it away from me..... I like the smell though......The base is about 25 lbs now.......Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:How big is this name going to be? Must be some REALLY LONG name. Are you going to add wheels to it to make it easier to move around, or just make a place to slip forks under it to lift it with a forklift?
Reply:Why 6010 for the first pass? Did you grind after the 6010 pass?
Reply:6010 on the first pass just for the practice mostly..... No grinding on the 6010........I did grind the top part to be smooth so that the letters will sit flat......... and have a smooth appearance on the finish.......18 feet of welding.... it was the most fun I had all weekend.........I'm aiming for 75 lbs on the finish product.........I'll be getting burnt orange paint mixed next week or the week after so I can start painting the finished product in December...... I'll post pics when done.......It will say "HOOK EM"........ Texas Longhorn fan........Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:The welding looks great. I just broke my stick out for the first time in years. I got inspired reading on this site. Is there going to be any strength needed in the sign? Did you weld it up that solid for practice or because you wanted a good looking weld to show? Seems like overkill for a sign. Just curious, not critiquing.
Reply:I welded up for strength for practice...... total overkill for what this is....... just saw a great opportunity to burn some rod in a flared bevel....... which I have been itching to do for awhile just didn't have the material to handle it on a project until now........The sign will sit on a desk or book shelf..........Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Did you do your fill/cap with stringers or some kind of weave, etc.?
Reply:Stringers......No weaves.....Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Nice job! You get your money's worth out of your rods....nothing left to use for tack rods
Reply:Just cause im kinda anal, your head is too close, your rod angle is pushing and you should strike ahead of the arc, lift move to the crater and begin.I forgot how to change this.
Reply:Good points Lawson.......My head is close....... I need a better diopter.... Eyesight is not 20/20 or even 20/50 anymore.......I'm working on the angle..... Still a learning process.......My instructor tells me my tie ins need work........ Among other things..... He is absolutely right........Your anal observations are dead on accurate........ All need improvement and I am working on it........Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Looks like you're having fun, thats all that matters! I have people tell me I overbuild things, but I could care less...Ill be watchin for the finished product [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:you didnt put three passes on the bottom?????i hope you dont drive that near my family...
Reply:Originally Posted by woodsmaryI don't think I've seen much stick welding before.
Reply:Originally Posted by weldbeadyou didnt put three passes on the bottom?????i hope you dont drive that near my family...
Reply:Originally Posted by Bigrich954rrwhat ???? over all it looks good
Reply:Originally Posted by FexalGood points Lawson.......My head is close....... I need a better diopter.... Eyesight is not 20/20 or even 20/50 anymore.......I'm working on the angle..... Still a learning process.......My instructor tells me my tie ins need work........ Among other things..... He is absolutely right........Your anal observations are dead on accurate........ All need improvement and I am working on it........
Reply:Hey Fex, great video.I'm wondering why you picked that rod angle as well. Seems like you were pushing like a mig. Did you have any inclusion problems?TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:No inclusion problem that I know of......The rod angle I was aiming for was 90 degrees....... But as a student Who is having a blast leaning, I find that the video helps me see areas that need improvement outside of school....... Such as rod angle....Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/ |
