Welding/Grinding Curtain
发表于 2021-8-31 23:14:12 | 显示全部楼层 |阅读模式
Not really much fab work here... but thought I'd post it up in case it gives some of you guys some ideas.  I needed something to block welding and grinding sparks from my work bench area, and this is what I came up with.  I already had a 6x8' welding screen thing so I made it around that, centered between the ceiling and floor.  There's a gap at the top and at the bottom but I think it'll still stop 99% of the sparks.  I have a 6x8" welding blanket with grommets that I can hang up there as well.  I started with 17' of 1/2" black pipe and made all the brackets out of 1" square tubing, 1" angle iron, 1/8" flat stock and 5/8" rod.  Sorry for the poor quality pics... all I had with me was my iPod.
Reply:Pretty sweet!  Only seen curtains in the schools nurses office like that before.  I was expecting one of the standard free standing welding curtains.  It's also a good way to screen off a section that is seldom clean!!
Reply:I like it.  Wondering if you can get a close up of how you attached the curtainThe Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:I'll try and get some... I'm away from home for the weekend though.  The curtain has reinforced holes/grommets in it and I just bent up some hooks from 1/8" rod that hook into them and over the pipe.
Reply:I bought one of these for my 5X10 Plasma table.. I really did not what to mess with a water table at this moment, and the fans/blanket work great for smoke, and dust.http://www.ebay.com/itm/Revco-30-oz-...item335e9e91cb Attached ImagesEsab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
GMT+8, 2025-12-27 22:26 , Processed in 0.134013 second(s), 18 queries .
